  New Posts New Posts RSS Feed - 60 degree horn with smallest cut out
Risc_Terilia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Risc_Terilia Quote  Post ReplyReply Direct Link To This Post Topic: 60 degree horn with smallest cut out
    Posted: 12 June 2017 at 2:06pm
I'm after a horn to load a 1" or maybe a 1.4" into but it'll need to go in a MT112 type 12" horn path so I need it to be a maximum of 15cm x 15cm to have as little acoustic effect as possible on the 12".  Does anyone have any suggestions or is 60 degree dispersion just not available for a horn that small?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Risc_Terilia Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2017 at 2:17pm
Ah looks like I can use this http://www.bluearan.co.uk/index.php?id=BACME10 rotated so it's 60x90 Smile
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2017 at 2:29pm
wouldnt do that.. the smaller the horn, the higher the cutoff, the bigger the issue with the 12".. get a nice large 60x40 horn for proper pattern control and low xover.. those pseudo coax arrangements are not an ideal compromise imo..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Risc_Terilia Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2017 at 3:58pm
Thanks for the reply. It's not a standard mt121, there's a 6" horn in it as well so the 1" meeting the 12" isn't really an issue.
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2017 at 11:09pm
make sure the 6 & 1 horns match dispersion wise, at xover
btw: how wide is the box?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Risc_Terilia Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2017 at 8:08am
The 6 is 75 degree so it's not bang on but near. Usual mt121 width.
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2017 at 11:24am
Faital STH100, may be worth a look
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2017 at 11:44am
they're studio45's old tops aren't they?
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2017 at 11:56am
Eminence lt250 is another option, perhaps more suitable dispersion
are you looking at replacing the comp?
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2017 at 12:29pm
though without a doubt, best way to spend your money is do away the 6 and put a faital / 18sound 1.4" on either respective tractrix flare in it's place
then find someone to help you align the box (or system) in smaart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Risc_Terilia Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2017 at 3:33pm
Yes that's right they're Studio45's build.  That Eminence lt250 looks just the ticket but it seems to be pretty hard to come by - I think I'll just rotate the horn I have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2017 at 7:21pm
where do you cross the 12"? 600ish hz? if so i wouldnt worry too much about obstructing the horn path of the 12s.. finding a horn that suits the dispersion, as mentioned above, and putting it as close as possible to the 6" is more important imo.. lots of 1" horns available from bluearan or elsewhere, without proper polarplots of the 6" horn its more guesswork than science to match those two :)
