8"+1" |
Post Reply | Page <1234 8> |
T-Bone
Registered User Joined: 27 December 2005 Location: Tampa, FL USA Status: Offline Points: 292 |
Nice work dlyxover, still waiting for the plans and passive crossover plans also, thanks alot for the update!
BASS, how low can you go!
kr1sounds
Young Croc Joined: 28 June 2014 Location: ThePromiseLand Status: Offline Points: 920 |
what does the sovereign 8 225 sound like? a friend of mine wants me to design them a simple 2x8 + 1 box and sub (fane colossus 12b). i'll use bassbox to design it
Edited by kr1sounds - 06 May 2015 at 7:19pm |
fostonshfs.webs.com |
MarjanM
It sound surprisingly good. Can take lot of power too.
Be careful when bolting it down. the chassis is very weak and it flex. Let it play during bolting because the flex is changing the sound. Kinda like aligning a HF driver recone kit. Edited by MarjanM - 06 May 2015 at 8:30pm |
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1502 |
For the cost they sound really good.
In my cab it needs a boost to bring the low out, I think heavily dampening really cleans/clears the mid range and makes it sound more focused (to my ears). They are going to be used as delay/fill boxes. They do take power well as MarjanM said, I'm running it from a C audio pulse 2x1100 on the 8" and 4x300 on the 1" with DB mark doing the processing.
Not as refined as I would like but very useable, for a budget jobbie I don't think you cant go wrong. I've got a few more tweaks I want to try time depending. |
In the Truth there is no news, and in the News there is no truth
Timebomb
Theres a new ali chassis version out now, i also quite like this driver i doubt theres much better out there for the price. |
MarjanM
Cut it at 1200-1500hz and it sounds good. 2khz is a bit pushy.
Teunos
Its an 8", 2khz can easily be achieved with a quality 8". Also, how do you know, have you heard it, i guess not. |
Best regards,
Teun. |
dlyxover
I've not found the 8" sounds pushy crosssed at 2Khz.
MarjanM
Yes i have some boxes that are using the fane 8-225 crossed over at 1.9khz to a BMS4524. Sound lovely.
kr1sounds
I was thinking 1.8kHz, looks like i may drop it to 1.5
dlyxover
For me its how the 1" & 8" interact with each other.
The lowest I take would the 1" is 1.9khz as I feel it starts to sound pushy. If i used a different 1" i would drop the crossover some but I do like the 1" I've used Edited by dlyxover - 08 May 2015 at 12:05am |
kr1sounds
I'm thinking of going for a 1.4" - P-Audio SD-63BF-1.4 comp & P-Audio PH-3022 flare
Edited by kr1sounds - 08 May 2015 at 5:01pm |
