8" or 10" mid horn plans need |
ivan
Joined: 08 September 2006 Status: Offline Points: 8 |
Topic: 8" or 10" mid horn plans needPosted: 09 November 2006 at 9:42am |
I am trying to design mid horn with 8" or 10" driver but i don't quite understand everything in Hornresp program. I always get that Cir is smaller for something...And when i try to fix it it stays there, the error!?
![]() Then i found some Java platform calculator but it allso doesn't work. Just to mention that i have built speakers with software simulations bass refleks and other tipes which are ok. I have red meny, meny things about horn type speakers but the simulation is that i can not understand! ![]() Are there any projects with this type, relatively small, drivers? I can see that usual minimum driver for mid is 12". And allmost forgot, i want mid with around 250Hz and up to 2-3Khz. Edited by ivan - 09 November 2006 at 9:44am |
Tom Umney
Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
Posted: 09 November 2006 at 11:21am |
Single 10 inch horn loaded?
Theres a 10 inch horn loaded design on that link. Use babelfish to translate the text as its not in english.
Tekasis
Posted: 09 November 2006 at 3:57pm |
babelfish ???
Never heard of it, but it's brilliant Toxic. Cheers.
jethrocker
Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
Posted: 09 November 2006 at 5:15pm |
Also 8" section from xtro cab, but 350Hz upward only according to spec.
MT102, from the speakerplans site, not sure if that will hit 2KHz up top though?
ivan
Posted: 10 November 2006 at 3:38am |
Thanks Toxic! Something like that i was looking for!
Another question: What kind of driver do i need for mid horn? I know only tha it needs low Qts, but not how low? |
Tom Umney
Posted: 11 November 2006 at 8:04am |
ivan
Posted: 13 November 2006 at 3:36am |
Thanks Toxic!
Tweet
