Post Reply | Page 123> |
simo69
Old Croc Joined: 29 September 2005 Location: United Kingdom Status: Offline Points: 1890 |
Posted: 28 November 2007 at 9:38pm |
TURBOSOUND
***** In your opinion / past experience *****
1 x TSE218 (2x18") underneath 1 x TMS4
or
1 x TSW721 (1x21") underneath 1 x TMS4
Edited by simo69 - 02 April 2008 at 11:32pm |
ceharden
218 might be louder but 721 probably sounds nicer.
simo69
218 being louder due having 2 drivers in one cabinet???
... althought a 21" is the same watts as 2 x 18" drivers???????
ceharden
Two 18" drivers will have a larger radiating area and handle more power than a single 18" driver.
Power (Watts is the unit) on it's own does not make a system loud. Driver and cabinet efficiency plays a very large part. |
simo69
What about the radiating area of a 21" in comparison??
simo69
the radiating of the 21" Vs. the 2x18" being the comparison here...
JaKe
Young Croc Joined: 14 September 2007 Location: N.E. Wales Status: Offline Points: 684 |
If using four or more bass cabs a side then I would go for the 21's otherwise the 2x18's.
A TMS 4 stacked on top of a 21" isn't going to be tall enough which could be a bit of a PITA. I prefer the 21" and in stacks of 4 or more, I think they would match up better with the low section of the TMS4's |
simo69
simo69
My system is in the middle, I am debating whether or not changing 218's for 721's or maybe just adding to the system..?
JaKe
As you already have the 218's why not see if you can hire some 21" to try.
JaKe |
simo69
I have purchased that TSW721 from 'champion' and managed to get a pair of PD2150 drivers. Will try out tomorrow, although it will be a 218 vs single TSW721 comparison.
Turbosound have given me the rough ULTRADRIVE delay settings to play with... here goes.
BlueBoxJunkie
Registered User Joined: 03 September 2007 Location: Midlands Status: Offline Points: 41 |
you only get out what you put in, if you drive the speakers with the right amplifiers they are gonna sound pretty good. here are three tips to make you go deaf in style
Tip one....ditch the Ultradrive and get yourself a bss minidrive
Tip two....Powersoft Amplifiers with power factor correction(non of your behringer rubbish)
Tip three.....Old blue boxes still sound good but theres a hell of a lot more out there these days
I run EV Dml midtops and 18" Jbl Loaded G subs bottom end active 3 way.
you dont even need ears as these G-subs will shake the sh*t out of you arsehole, I now
you dont get as much throw but who needs the sandwiches dancing on the plates nextdoor anyway.
not much help really but at least i had a say.
Blue Box Junkie (Rehabilitated)
