  New Posts New Posts RSS Feed - .
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Topic: .
    Posted: 20 October 2012 at 10:30pm
Edited by mk2_ginger_biscuit69 - 18 March 2013 at 5:37pm
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2012 at 11:54pm
http://www.eserviceinfo.com/downloadsm/35375/kef_psw2000.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2012 at 12:01am
cheers chris!!
wayward91 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayward91 Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2012 at 1:24am
i have one of these with the exact same issue. iv decided to power mine with a separate amp. these things seemed to be going bang by the dozen ! i thought it would probz only just go bang again . the woofer in these is quite nice, fairly substantial . sounds nice too, starts to loose it a bit when pushed though. not sure if its the ports or the woofer.
Edited by wayward91 - 21 October 2012 at 1:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2012 at 1:31am
good to get some feedback, hoping this sounds alright used alongside Alesis M1 active Mk2 5point surround system. Will give it a go fixing, dont think its too serious, as signal reachs the cone still. Hoping its just a few small resisters/capacitors then alls gud.
Tan-2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tan-2 Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2012 at 11:15pm
had one of these amp in for repair,,,had to mod it via bolting it's dropper resistor for the low voltage rails to the heatsink plus the relay buzzed due to the 47uf 63v cap going dead short.. check the schematic on line there's a guy who's carried out so many mods on this amp...
it's just bad that so many things have to be done just to keep it alive!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2012 at 11:38pm
Start by scraping off all that brown sonybond glue. It is conductive.
North Staffordshire
