  New Posts New Posts RSS Feed - .
Dub Specialist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Topic: .
    Posted: 20 February 2013 at 3:05am
Edited by Dub Specialist - 20 February 2013 at 10:35pm
tall_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tall_mike Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2013 at 5:50am
It's totally and utterly pointless trying to squeeze 4mm cable into a 13a plug. it's a waste of copper!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2013 at 11:35am
I had a Crown MA2400 with a similar problem, ie oversized mains inlet cable. I imagine it was a leftover from the original 110v design.
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2013 at 11:39am
Was told 4mm Arctic Blue fits decent 13A plug no problem.
3G4 HO7-RNF, different story I would think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2013 at 12:24pm
Edited by Dub Specialist - 20 February 2013 at 10:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2013 at 12:43pm
The problem is that it won't fit? You seem to have answered your own question…
For the what, 50cm your tail is going to be the change in cable thickness isn't going to make a huge difference, particularly as you're limited by the fuse anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2013 at 3:08pm
Edited by Dub Specialist - 20 February 2013 at 10:38pm
billso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote billso Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2013 at 5:28pm
Originally posted by Dub Specialist Dub Specialist wrote:
so there be no problem ie voltage/amp/current ect with using 4mm in the tail then..? coming from a electrician's point of view?
thanks
The problem is it will probably fail a pat test.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2013 at 6:06pm
..no good to knowone Dead hope yu happy ginger
Edited by Dub Specialist - 22 February 2013 at 10:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2013 at 6:06pm
if the cable is too large, it would not be in the plug manufacturers recommendation of usage of their product, which would make it a PAT/general fail. The cable strain relief, and physical hole, will be made for a certain diameter cable thickness which must conform, as will the terminal holes for the cores themselves - they must all fit in properly within design specifications.
why bother regardless, does it really matter if your cable doesn't look phat? Are you some kind of closet audiophile who must have cabling resembling a dildo or something?
If it is running off a 13A fused plugtop, then 2.5mm is the maximum any sane person would ever need. If running without a fuse, you are an idiot [not that you are i hope!].
Edited by mk2_ginger_biscuit69 - 20 February 2013 at 6:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2013 at 6:09pm
dildo or something? no mate im not on the orther boat trusssss me
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2013 at 6:13pm
try putting your cable in black garden hose and fill the hose with shot pellets? That will make it pretty hefty looking Wink
only jokes, sorry, just can't see a serious side to what you are asking about, especially after multiple replies which i shall summarise to the word of 'why?'.
Edited by mk2_ginger_biscuit69 - 20 February 2013 at 6:13pm
This page was generated in 0.093 seconds.
