a stonecold Matrix |
Post Reply | Page 123 11> |
SMP
Young Croc Joined: 16 March 2013 Location: East London Status: Offline Points: 1226 |
Posted: 14 September 2014 at 3:58pm |
I have here a Matrix XT1200 apparently modded by Matrix
there is a problem with it as I see it It does not get hot or even lukewarm at idle with the fan disabled. very odd for a Class AB after an hour or so it is still cold to touch Perhaps I am missing something here but think not I am beginning to realise it is not what it is said to be. just a class B driven by a Pseudo class A driver VAS that isn't either anyone any thoughts on this? |
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
have you turned the amp on...
sorry, could not resist....
kedwardsleisure
not sure I understand, does it work ok?
North Staffordshire |
SMP
well that is the question it functions ie passes a signal with power gain but "working" that is the issue in hand Hardly Class AB if there is little or no dissipation within the current stage Either that or someone changed the Laws of Physics and I never got to hear of it. |
ceharden
I would stick it on a scope or better still a distortion analyser and determine whether the cold biassing is causing an issue with crossover distortion or not.
RobinMatrix
Young Croc Joined: 23 August 2013 Location: Kidderminster Status: Offline Points: 567 |
How does it sound?
They do have a fair bit of heatsink ... and only dissipate around 5 to 10W a channel in idle ... which may not be enough to detect by hand ... if you have a scope, a lack of bias current will be easy to detect on small signals. It is unlikely that both driver chains failed identically, at the same time ... it could simply be working perfectly ... |
Matrix Pro Audio ::http://matrixproaudio.com/"
kedwardsleisure
All the matrix amps Ive seen run with little quiescent current anyway, that's got to be good. Never seen one with crossover distortion either. Dont forget you're dealing with lateral mosfets which have better current sharing across the current range from threshold to clip. (wot no emitter resistors!). Its an inherently stable design in that respect.
mini-mad
Xt1200??!!!..... wen he start building them?
Heathrow_B_line
Old Croc Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7344 |
+1 is it 1u??? |
SMP
Thanks(1)
my mistake "GT1200FX" I am aware of the device type as well to add I am given it's setup as per the owner who paid to have it specially done as class AB. but not class AB in my book. either way a very bad utilisation of the "Hitachi Circuit" as it is clear to hear. replaced with an amp that is sonically better but opened it up to be nosey to find cheap nasty inside got more nosey disabled fan see what went on Which brings us here to Cold running "Class AB" Which is also how come? I will get some kit on it take some data and see where it is at. just a piece of junk someone else needs to be owning as it will end up on ebay soon |
AM55
Old Croc Joined: 16 August 2007 Location: Matlock Status: Offline Points: 1728 |
Facepalm.
James Tengo
Old Croc Joined: 09 May 2008 Location: Brighton Status: Offline Points: 2155 |
I quite like the sound of an Xt1200.... They run fairly hot though Edited by James Tengo - 15 September 2014 at 6:41am |
