  New Posts New Posts RSS Feed - ? about Crown MA5002VZ
MrDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrDJ Quote  Post ReplyReply Direct Link To This Post Topic: ? about Crown MA5002VZ
    Posted: 20 January 2010 at 1:29am
about the vz mode switches, what setting should it be at for bass speakers like scoops?
VZ (Variable Impedance) mode
VZ-ODEP mode
Lock Low mode
Loudspeaker Offset Integration
thank you
VentureSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VentureSound Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2010 at 1:40am
Hi,
VZ mode is dependant on the load impedance. But since you haven't said what this is, then switch to VZOdep, which is the safest.
Turn off the loudspeaker integration, as it has a high pass filter function.
Hpoe that helps,
MrDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrDJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2010 at 1:43am
running 6 scoops 8 ohms per scoop 3 per side i think thats 2.6 ohms per side
cilla.scope View Drop Down
Legs all the way to her bottom....
Post Options Post Options   Thanks (0) Thanks(0)   Quote cilla.scope Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2010 at 1:57am
you could try the lock-low mode at 2.6R see if it runs a bit cooler.
My girlfriend thinks I'm a stalker.
Well, she's not exactly my girlfriend yet ...
This page was generated in 1.562 seconds.
