above 4 scoop... |
Post Reply | Page 123 4> |
_Natty_
Young Croc Joined: 01 April 2007 Status: Offline Points: 663 |
Posted: 22 February 2010 at 8:19am |
i'm really undecided about my new 4 mid bass to put over my 4 18" super scoop
the fight is between: horns plan Vs reflex and any way have advantage and disadvantage... for shure i put one 15" b&c speaker on it...wich model allready don't know...any suggestion very wellcome ;) actually my scoop are cut at 100hz(i know that is not the best but i can't work on it for now) and for the upper cut of the 15" no prob i can set how i prefer... up i've 4 12" actually on a double reflex box... Imo: horns: (hd15, hd215, any else?) -very efficent -necessary for a decent kick section (?) -more wood and more time for building -more money to spend -i need an help for working on some parts... reflex: -easy to do -easy to project (i've some one at b&c that can model for me a box) -less wood and less time -l don't need any help for building -less efficent -delay problems (?) any help will be apreciated... |
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
king david
Young Croc Joined: 17 January 2007 Location: italy Status: Offline Points: 1324 |
i would go for the reflex boxes, if you use b&c and an amp that can give them enough power, u wont be disappointed, 4 x 15 reflex over scoops = good choice, and no delay problems between your system sections.
its less efficient than a horn, but again, you can just use a good amp and it would be fine.also maybe you dont need massive 100to200hz for the dub/roots you play
actually i built horns (es18) to go over scoops, but thats just cause i would use them as stand alone bass bins for live bands, 2 per side
_Natty_
http://www.freespeakerplans.com/index.php?option=com_jfusion&Itemid=64&jfile=viewtopic.php&f=16&t=989
is it for a fane speaker...so it's also good for a bc? wich one? any one have try it? kingdavid: Ciao ;) yes i know that bc needs more power than pd for example... but afeter some test 18" neo bc vs 18" pd i've found that maybe is less aggressive but more musically... |
bitzo
Registered User Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
to me the sim of bootybass is pretty optimistic, first because is simmed like a scoop and not like a tapped horn, second because hr is optimistic because model the horn with round surfaces. In the forum there's some variations around the bootybass concept. I quote king david for reflex, no delay needed but more watt needed for the same pressure of a horn.
cheers, bitzo |
king david
is it for a fane speaker...so it's also good for a bc? wich one? any one have try it? i built a single driver version, test would be possible, but we live too far. and i used a sonora midbass driver,not b&c one(i dont have any 15 from b&c, sorry for that!
and yes i also have b&c and i love their sound, and for kind of dances i'm doing, 3 hogs/b&c loaded are enough and sound sweet, 4th hog still wait its first dance. also i found some deals on b&c, impossible to beat, pd1850 would be more than twice the price...
mykey
reflex are no fun
http://forum.speakerplans.com/straight-kick-horn-the-mule_topic35786_page1.html Edited by mykey - 22 February 2010 at 12:35pm |
king david
yes, nice design and reflex arent that beautiful but natty maybe prefer something he can build by himself also i remember you advising 2 x 15" reflex in the old thread "battle of the scoop kick bins"
_Natty_
for the horns that's suggest mykey i've the same problem with all the rest of the horns plan:
angles angles angles!!!!! so i can do by my self any project but i need helps for cutting angles! also after some comment with someone who doing ts parm for big farm i can't trust in it!!!! so simulation for me aren't good at all, never! ;) i trust just in my hears and i can say: -hd are very good but i've heard it just with pd, so i don't know if it's still ok with some bc driver -the last 15" reflex good that's i've heard are on Shilo's sound (something like the bc sub project but turbomax loaded maybe) but the noorth arena is really small so i don't know if i can trust in this test....and many sounds that have reflex are moved to horns.....
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
15" reflex above scoops, is simplistic solution, but in all honesty, "optimum" performance requires every cab above a scoop to be delayed appropriately. 1/2 USBs will be louder than 15s, and require less power/drivers to do it, and murder 15" reflex inside or out. |
bitzo
that's interesting....so you can obtain real prooved ts parameters, than sim a cab with that....than build the cab simmed and load it with the same driver with prooved parameters and if this guy have the equipment to measure the spl you can obtain the real scientific truth about simming. |
_Natty_
yes but also a softwere simulate it...isn't the truth again!
maybe relly near but i prefer my hear
