  New Posts New Posts RSS Feed - active crossover
active crossover
krazyneil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote krazyneil Quote  Post ReplyReply Direct Link To This Post Topic: active crossover
    Posted: 09 July 2016 at 11:51pm
ok this may sound daft
if im using an active crossover to seperate the bass and mid high do i need to use an amp for each or can you configure it so your taking the output from the amp and splitting it through the crossover ?
GOD TOLD ME TO DO IT !!!!!
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2016 at 12:16am
An active crossover is for low level (not amplified )signals. A passive crossover can be used after amplification.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2016 at 12:51am
take outputs from x/o to inputs on amp , you can use mid one side , tops orther side ect
AJ113 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ113 Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2016 at 9:17am
Yes. If it's a stereo amp you can use one side for mid high and one for bass because stereo amps are basically two amps in one unit.
Quote or can you configure it so your taking the output from the amp and splitting it through the crossover ?
Do not do this. You will be sending amplified power into your crossover, which will fry it.
MattStolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2016 at 10:34am
It is a question of voltages.
Mic outputs are around 5mV (0.005V), nominal "line" level is around 1V (strictly 0.775V, or 3V DC from a Pioneer DJM) and the speaker level can easily reach 50-100V, some big toys can make 200+V.
You can imagine what would happen to components rated for 10V max, having 100V shoved up them. They tend to "fail".
Post Options Post Options   Thanks (0) Thanks(0)   Quote krazyneil Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2016 at 10:53am
thanks guys it was one of those late night things that was frying my brain
unfortunatly the matrix ukp2100x isnt really powerful enough to use it one chanel for tops and bass, best laid plans an all that lol
so ill have to start saving for a  2u 4 channel amp to fit in its place ,might try out the thoman tsa 4-1300 as they seem to be well though of for a cheapie 4 channell and would have enough power till i can get somthing proper in there
thanks anyways guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ113 Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2016 at 12:12pm
Why can't you just buy another amp to go with your Matrix?
Post Options Post Options   Thanks (0) Thanks(0)   Quote krazyneil Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2016 at 12:24pm
just a space /compactness thing
if i buy another amp then ive got to buy another rack so 3u box turns into 6u box and the extra weight its only for a simple sytem of  18" subs and 12/1 tops
trying to upgrade and make everything smaller and lighter lol
