Alternative version of WSX (plan) |
Post Reply | Page 12> |
Amano
Registered User Joined: 06 October 2008 Location: Russia Status: Offline Points: 219 |
Posted: 27 January 2010 at 7:54pm |
Amano
same horn path, same response... smaller.. easier
Quantum Sounds
Registered User Joined: 26 December 2008 Status: Offline Points: 462 |
nice one anano
should have a better responce higher as the bends are kept around 90deg rather than 2 180's |
Saul
Old Croc Joined: 15 June 2007 Status: Offline Points: 5912 |
20mm difference between the two - was it worth the effort?
mykey
I like it
WSX made simple not simpler |
FlipC
Young Croc Joined: 25 October 2007 Status: Offline Points: 654 |
OK
Trying to get my head around this layout. So would the access hatch be from the front inside the mouth? With driver firing through the section that is 144mm? If so where would you personally run the wiring? I ask as that grey part which would be on what I think would be the access panel looks like a connector. |
Amano
That grey part is like http://www.audioroundtable.com/PiSpeakers/messages/17999.html
This is a Heat Exchanger.
Access hatch is at the front of..
144x378mm is an original WSX throat area.
Amano
yup, it was!
this version hasn't parts having angles less than 45deg except for throat part... two ones
hatch is parallel to driver bottom to make heat exchanger
Amano
it shouldn't have big changes in response... maybe less distortion
_djk_
Looks like a good alternative to the often requested CV B36 types too.
djk
tomschute
Old Croc Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
Good effort - again
@ FlipC easy, just run wiring straight through the centre panel through to the back panel @ Amano width...? Edited by tomschute - 28 January 2010 at 9:57am |
www.stableaudio.co.uk Speaker Building Services |
Amano
574mm as in original
