  New Posts New Posts RSS Feed - alternatives for the 1850
dj-panoramix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2010 at 3:24pm
Originally posted by Father-Francis Father-Francis wrote:
Originally posted by Chrise Chrise wrote:
Any other alternatives? Because i cant get more void driver in germany :(
It will be cheaper to order the Void for Void or pap than buy a PD from http://www.thomann.de/
sad but true.
with the shiping price inclued i don't think so...Wink
PD188 is 178sterling to bluearan and 245euro(221sterling) to thomann:
void V1000 is 209 sterling:
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2010 at 4:54pm
i think speakerstore.nl do them too.. if you can't find someone in germany.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2010 at 5:15pm
450euro LOLLOL
i wish it's price for 2...Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2010 at 9:02pm
i didn't check the price...
should be cheaper now.... a few years ago they cost me about €300 each from pap.. but the pound / euro rate has changed a lot since then.
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2010 at 9:42pm
sad but true.
maybe you don´t get what am saying here it is
http://www.thomann.de/gb/precision_devices_pd1850.htm
if you buy the Void from pap / or Void in UK you´l pay 209£ so what am saying is buy the void , the bin is almost the same as the
http://www.proaudioparts.co.uk/looneybin.asp
so even if he pays 30£ for shipping the Void is cheaper @ pap/Void call it what you like .
I didn´t say better or anything else , said cheaper Ouch
Optimism means expecting the best, but confidence means knowing how you will handle the worst. Never make a move if you are merely optimistic Music is the strongest form of magic.(+45 31879997)
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2010 at 11:00pm
yes but the builder was talking about PD188 not PD1850, and that's why i misunderstand your post because i didn't see that you was answering to chrisse.
Edited by dj-panoramix - 04 March 2010 at 11:06pm
vmh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vmh Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2012 at 1:00am
Dj-Panoramix wrote:
for me the real winners here in order are Void V1000, RCF G/N402 and then PD1850
then come in order: 18W1000, RCF G/N401, PD188, PZB100
Hi Dj-paroramix.
Where you say RCF G/N402 (or 401) Does this mean you can use ether The G401 or the N401?
RCF only seem to list the G401 now which would be the better choice for me, i think as i will be driving four with a VZ500 which will give me more head room with the 900w G401 than with the 1200w N401.
I am thinking of using 4ohm drivers to get the most from the amp, although with the 900w G401 i could still run the amp at 4ohms a side and still have good head room.
The reason i am stuck on RCF is because i can get them at cost price, Knocking a good 400 quid off the final build cost.
Any thoughts?
It's not how big it is, it's what you do with it!
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2012 at 2:50pm
celestion cf18.....
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2012 at 3:21pm
on simulation all this sim pretty well: 18sound 18W1000, B&C PZB100, RCF N402, N401, PD188, VoidV1000...
all sim in 0,5PI PD1850 is allways in grey so the other driver in black,
pd1850 vs 18W1000:
Unfortunately, in reality, often, many sims don't add up to dry dog sh.t when it comes to actually testing drivers in cabs.
T/S parms give you "an idea" of which drivers "may" be more suitable to certain cab types, then you choose driver according to budget.
Always best "if" possible, to try one driver in your cab first, before buying.
Which is why many manufacturers send "test" units to certain individuals/corporates.
Tweeter_Box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tweeter_Box Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2012 at 9:55pm
pd1850 vs 18W1000:
Clap
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2012 at 8:24am
Actual T/S parameters as well typically vary by a huge degree from the published figures.
Never understood why so many folks put their faith* in simm's and build multiple boxes based on them without doing a test box first.
Tony
*Even get their boxers moist!!!
www.forteaudio.eu - BMS - db-Mark Processors
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2012 at 1:05pm
Yep, probably only reflex cabs where Sim software is typically pretty accurate.
If using quality software, and driver manufacturers who don't "fudge" parms that much.
WinISD is typically good parameter fudge detector. LOL
speakerplans@redhotmail.net
