Amano -the legend-(compact scoop by Amano) |
Post Reply | Page 123 5> |
tda-audio_2
Registered User Joined: 13 February 2007 Location: United Kingdom Status: Offline Points: 37 |
Posted: 01 October 2013 at 3:52am |
regard
on forum often saw work AMANO 1х18" 2х18" 4х12" and others work AMANO I have asked амано develop me compact scoop 12" and 15" with necessary me size and range 65-90hz (small renting) here is that beside he was got in drawing but adapted under itself and here is result. very compact efficient scoop
and 12" Scoop by AMANO |
dtb
New Member Joined: 18 September 2012 Status: Offline Points: 3 |
could someone help me with some of the panel sizes for the amano 12" scoop .
I think they should be sides 450x550 mm top/bottom 450x304mm back 512x304mm baffle 315x304mm first internal panel ? 228x304mm????? second internal panel 193x304mm???? port shelf 310x304mm port brace 310x197mm got a sheet of mdf waiting to be cut just want to be sure i have it worked out right before i cut anything Edited by dtb - 03 October 2013 at 6:58pm |
cassiya
Young Croc Joined: 13 January 2013 Location: london Status: Offline Points: 626 |
Any plans for the rest of the Scoops? and what drivers are the 12 and 15????
Just because you got more boxes that don't make you a man....
tda-audio_2
measurements -ciare 12.00sw\15.00sw (rubber)
dtb
tda-audio_2
Scoop-Flex 12 vc Cubo 12
Scoop-Flex 15" Ciare 15FXE4 vc 15.00SW (ruber) |
MrNobody
New Member Joined: 06 March 2014 Status: Offline Points: 2 |
Hi guys!
I know this is an old thread, but as I want to give feedback on the 12" compact scoop by Amano, I think this is the best place to post it. So, I wanted to build a 12" subwoofer for a 50m² garage we use a few times a year to party. The requirements were simple: - No (or very low) budget - Easy and quick to make - Descent performances Audio-grade wood is very expensive. So I've decided to use shuttering panels instead (the panels used for construction when you have to flow some concrete). They are made of 3 pli pinewood, are 25 to 30 mm width, and very rigid. But, as their standard with is 50 cm, I had to choose a compact design. That's why I've chosen this compact scoop. For the speaker, I 've used an old 12" Monacor 175w (rms). I've adapted the dimensions (+/- 10%) from the original plan to have the fewest cuts to make. So, I think it's not perfectly sound optimized anymore, but as I don't even know the Fs and Qts of the speaker I've put in it, I don't care. The build time took 3 hours, gluing and painting included. Here is the result: Here is the plan: I've used one 2.5m board of shuttering wood and some spare wood I've found at home. (price: 15 $) With one board you can build the whole external enclosure. The spare wood was used for the acoustic circuit inside. The pieces of wood are glued and screwed together. I've tested it with one channel of an old BST 2x150 Wrms amplifier, connected to the sub output of a Behringer equalizer, with crossover at 125 Hz. The result is... well.... better than expected. The bass is clean, deep, but could be a little more punchy. With an equalizer, you can easily correct that by putting a few dB more between 80 and 100 Hz. But for sure, for the 50m² garage it will be powerful enough to make some objects drop from their shelves :-). I have no tools for sound measurement so I cannot give you more information. If you want to build a very cheap and compact 12" subwoofer out of shuttering panels, this is the best design I've found on the internet. And the result sounds good enough. |
ODea
Registered User Joined: 15 July 2012 Location: South Status: Offline Points: 41 |
Where's the 18" plan?
TONY.A.S.S.
Well, you have used to worst wood possible for a speaker, although it would be even worse if it was sealed, so lets hope, as the cab is open ended, that you get something decent out of it. Soft wood with grain is usually a no no with speakers.
By the way, I love the fridge grills on the front. Edited by TONY.A.S.S. - 06 March 2014 at 4:07pm |
MrNobody
Thx for the remark! The grills in front of it are from an old hamster cage ;-) I'm aware that the choice of the components, including the speaker itself, were heavily constrained by the budget.
I've used it a whole night for mixing with 2 active 12" speakers at loud volume, and it actually works well, with a real infra bass response and with clean and round bass overall, without any noticeable parasitic noises. Maybe the fact that it's loaded only with a 175 Wrms speaker limits the bad wood problems. That's just my opinion. It's the first time I try to build a speaker, and I don't have another sub to compare it with. For my needs (installation in a garage), it is perfect. But if i build another one, I'll put some money for better wood, and better grills ;-) |
TONY.A.S.S.
At there end of the day, you have to be happy yourself with you efforts irrespective of anything else, and if it sounds good, it is good.
KidCreole
Old Croc Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3600 |
Hamsters are happy. They have now run away
