American Audio V6001 Plus ??? |
Page <1234> |
| Author | ||
DjLeco
Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 408 |
Posted: 23 January 2012 at 8:40pm |
No any intention of blame, at your adress, all appologies!
Pictures and real tests, and how I have restaured 5000VZ is here:
And yes, both channels at mine first amp, was ok, but VZ switches, faulty!
![]() FIRST amp
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Second amp:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And real tests, after restauration:
Me, Myself and I,the ONLY one...
DjLeco
Posted: 24 January 2012 at 6:25pm |
Mr Abeltronics, please watch here:
RosscoPico
Joined: 31 January 2007 Location: Brighton, UK Status: Offline Points: 827 |
Posted: 27 January 2012 at 2:01am |
Hi Lewis, good to hear your opinion on this and it's good to hear that you conscientious with regards to your test results and conclusions made - I certainly think a 2nd round of testing of the Crown should rectify these uncertainties.
@DjLeco - it certainly seams that you have invested a good amount of love and care into your fine amps and I'm sure that they serve you very well. Interesting to see all those detailed pictures of the internals - I'm no expert but they look well spec'd, have a decent layout / configuration and a large amount of electronic components inside them. As I mentioned before, I must try and get my hands on one soon and see/hear what my ears are telling me.. I'd been feeling that this has become the "Crown VZ6001plus" thread, but I see you've started a new one now so that was probably a good move :)) Amp meet 4 anyone (or is it 5 / 6 now...)?! Next I'll be reporting on my latest findings of the American Audio MA5000VZ internals *coming soon* ...
Edited by RosscoPico - 27 January 2012 at 2:04am |
RosscoPico
Posted: 27 January 2012 at 2:13am |
Hi Lev - on further inspection, the v6001 has 12x "15000 uf" caps (please see my photo below) and high current rectifiers so no probs delivering the power to the o/p stages.
From further discussion with my colleague, we have run these amps in 4 ohm bridge on numerous occasions (which I wasn't fully aware of before..) and they only warm up slightly but they certainly deliver the output in this mode. They also have quite a reasonable 'brick wall' limiter in them so as long as your speaker ratings are proportional you wont run into clipping however you can turn this off. 1 amp on 2x 1800w (AES) subwoofers can certainly get our "Predator 118N" heat sinks hot!
Tekasis
Posted: 12 May 2012 at 1:36pm |
Rossco, someone's (non-member) asked me ask if you still have any of these used American Audio V6001 Plus amps for sale which were on the for sale thread before but has since been locked! or have they gone?
Any one else using them on bass/sub?
**Heavy Weight-Line**
A home without books is like a body with no soul. |
kedwardsleisure
Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 2483 |
Posted: 12 May 2012 at 2:09pm |
the American Audio are very good build quality compared to the other lookalikees. Everything actually fits together as it should. Its CE mark will no doubt also be genuine.
North Staffordshire |
RosscoPico
Posted: 12 May 2012 at 3:24pm |
Hi Kevin, It's good to hear your opinion on them - we've not had any issues with our V6001's, apart from one small minor gripe.... The grommet which the power cable comes out of isn't that great - i.e. if you are not careful with handling the amp, the mains cable can start to split where it meets the grommet if the lead gets pulled around too much. We've managed to get around this problem by tie-wrapping the power cable to the back of the chassis so it doesn't get strained at that point in the first place. Even better, a new grommet can be fitted quite easily (it only costs ~50p for a good one) then problem solved! Tekasis - I'm afraid we've sold both of those V6001's which I'd listed and we are keeping the other 2 we have for now. Having said that, we are changing over our bass amps to Matrix as the weight saving is a big benefit to us, mainly because the loading capacity of our Luton van is an issue we regularly have to consider! So a couple more used ones will be available at some point in the future... As it happens though, we've got a special offer on the V-6001plus at the moment..so you can tell your friend that I can sell this amp now for £650 brand new inc. shipping - that's not a bad price for 5kW of amp power I recon!
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11734 |
Posted: 13 May 2012 at 2:56pm |
Hi RosscoPico, no disrespect intended, but after looking at these
pics again, I find it very, very hard to accept, that this amp will
exceed the power output of CA18 on sub, 35Hz-80Hz, as specifications suggest. They just don't seem to have enough output devices.
Naphon Hi-1400 ![]() "Other Amp" ![]() Might be interesting to compare the V6001 with Audiocenter DA12.2 which have similiar specs, but proven 4 ohm performer. |
darkraver
Joined: 29 September 2009 Status: Offline Points: 135 |
Posted: 13 May 2012 at 5:44pm |
well just compare the V6001 with other amps it is quite good actually.
Sometime ago when I was selling some chinese amps we beated the V6001 (on power output). Anyway a pretty decent amp such a V6001 !!
levyte357
Posted: 13 May 2012 at 7:12pm |
Maybe someday soon, someone will organise 5K torroidial amp test.. ![]() |
kedwardsleisure
Posted: 14 May 2012 at 12:24am |
Build quality must always be factored into comparing any amps. An amp that is still delivering 800W after 10 years service will always be a better investment than a similar priced amp that delivers 1000W but goes bang after 2 years.
RosscoPico
Posted: 14 May 2012 at 12:36pm |
Hi Levyte, I think we are going round again in circles here, as you've still not successfully explained to me why the V-6001 amplifier won't manage to live up to it's quoted specification figures as I think you are suggesting? Please let me explain why I have this opinion.... Firstly, you have claimed that the V-6001 is supposed to be able to exceed the CA18 on sub. If we look at the specifications below, you will notice that this is an untrue statement; Crest CA18 (taken from the PDF manual for this amp)
From this you can deduce that in 4 out of the 5 measured ratings they are the same (with the exception of 8ohm stereo) for each amplifier with one important difference - the American Audio figures are measured at 0.1% THD+N which is a higher amount of distortion than the Crest's figures which are measured at 0.03% THD+N. From this we can establish that the Crest actually has better output figures, as they can deliver the same wattage output but at a lower measured distortion figures. If the Crest had been measured at 0.1% THD+N (the same as the V-6001) then the output figures would have actually been slightly higher than the American Audio! This might explain also why the 8 ohm stereo figure is 100w more per channel than the CA18. The circuity is a massive contributing factor which determines the actual sustained power output of an amplifier. It's not a simple as how many transistors are utilised in an amplifier design... As I have explained to you before a couple of times, the Void Infinite 8 has the same number (and type - i.e. Toshiba) of output transistors as the V-6001 but at the same time the Infinite 8 can deliver 3112 wpc into 2ohms continuous @0.4% THD (see Abletronics test results: http://www.abeltronics.co.uk/amptesting.php?z=Void_Infinite_8_mk2 That's 6224 watts continuous from an amplifier which only has 32 x 150w transistors (i.e. 4800W), so when you tell me again that " They just don't seem to have enough output devices. " when you are looking at a V-6001, then surely you would be saying the same thing about the Infinite 8?! The CA18 retails for £2899 so it's far more expensive, seeing I can offer to sell 4x new V-6001 amps for the price of just a single CA18! I wouldn't disagree that Crest is a better brand to buy (if they can afford it), and I'd happily sell someone a new CA18 over a V-6001 if that's what a customer preferred. Of course there's also the benefit of a 5yr warranty which is preferable! And seeing as we are now authorised dealers now for Crown, Crest, Lab Gruppen, Matrix, QSC, Yamaha as well as a few other well known brands, I'd actually be much happier to sell any of these to our potential customers as we would make higher margins on them and also I'd prefer to sell "British made" amps where possible. No disrespect to you either Levyte, but I thought if I explained this then you'd be aware that I'm not actually trying to "push" sales of the V-6001, but I'd still say that it has it's place in the market for customers who want to buy new and at a very cost effective price. Maybe we will discover one day that this amp is 100-200w underpowered at 40Hz but does this really matter much at this price?! Until we have got around to having one tested by Mr.Abel then I don't think there's anything to suggest that they are overrated in their specs (IMHO). All I know is that they've done us fine for bass duty on our own system. I do appreciate that you've had more experience with different amplifier brands than me, so you can still let me know if you think I'm missing a trick here... As for Naphon, I noticed that you posted on their forum a while back; http://www.naphon.hk/forum/forum_posts.asp?TID=16 You said "Lots of Sound systems over here want the HI-1400 amp, but there are no distributors !!!" So who is the UK distributor for Naphon or doesn't one exist still? I'd agree that the Audiocenter DA12.2 looks like a good amp, how much do they cost new in the UK?
Haha yes, maybe that's the only way we'll eventually see eye to eye on these matters then.. Edited by RosscoPico - 14 May 2012 at 12:37pm |
Page <1234> |
Tweet
