  New Posts New Posts RSS Feed - Amp Fuse
Amp Fuse
EGONick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EGONick Quote  Post ReplyReply Direct Link To This Post Topic: Amp Fuse
    Posted: 13 April 2008 at 7:05pm
I recently installed an amp in my car, all working fine till it was too close to the engine and snapped the power cable.
I've thought of loads of different alternatives to fix it and what I need to do is remove the fuse from the cable and move it to give me more slack near the battery so it can reach.
Could someone explain how to re-attach the fuse to the power cable once removed?
If it helps, the fuse box I've got is this - http://www.maplin.co.uk/Module.aspx?ModuleNo=30444&&source=14&doy=Search
Any comments or tips are much appreciated.
This page was generated in 1.250 seconds.
