  New Posts New Posts RSS Feed - amp fuses,quick blow or slow blow?
lickweed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Topic: amp fuses,quick blow or slow blow?
    Posted: 10 December 2009 at 3:47pm
Hi
I need to replace a fuse in mine mackie m1400 amp,its a 32mm,ceramic, 8 amp fuse.
 which one i should use-quick blow or slow blow.
Many thanks for your adviceSmile
djstefanos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2009 at 3:50pm
your topic sounds very dodgyLOL
Stray-Sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stray-Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2009 at 4:02pm
I did this once and the amp caught fire inside next time i switched it on
that was a slow blow fuse.. i just thought an 8 amp fuse would blow at 8 amps.. knows
DjMidKnight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjMidKnight Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2009 at 4:20pm
its a quick blow fuse, idk about mackie spacificaly but all of the ones i use are type ACG.
reality is meerly a compilation of what our limited sences precieve as being fact therefore there is no true universal reality and as such i propose that space and time can be bent twisted and altered
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2009 at 5:01pm
Thanks guys for infoWink
Im not an electrician and i thought that there are just one kind of fuses,but there are many.
So quick blow it is.
Thanks once moreSmile
Wrighty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2009 at 5:07pm
You can tell by the letters which are usually stamped into one or both end caps on the fuse. 5AT or T5A is anti-surge 5A, for example. 5AF or F5A is fast blow 5A. The same lettering code is often printed next to the fuse holder.
ALL YOUR BASS ARE BELONG TO US.
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2009 at 5:28pm
LOL maybe it's just you
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2009 at 6:12pm
maybe it is LOL
Centauri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Centauri Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2009 at 10:32pm
According to the Mackie service manual, the fuse should be an 8A SLOW BLOW type.
Usually the mains fuse on an amp is the slow blow type due to the filter capacitors initial inrush current which can pop a fast blow fuse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2009 at 11:30pm
Thanks again for your replies.
Some say slow some say quick.
In service manual its a 8a sb fuse which i presume is slow blow(sb).
So looks like slow blow.
I will email them just to be 100% sure.
Thanks everyoneSmile
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2009 at 12:16am
Make sure it is a ceramic type, they have powder in them to quench the arc that forms when they blow.
djk
brokenjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brokenjoe Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2009 at 10:11am
i prefer slow blow... depending on the situation and location
This page was generated in 0.062 seconds.
