Amp Internals 2 |
Post Reply | Page <1234 260> |
Oldmaelstrom
Registered User Joined: 07 October 2009 Status: Offline Points: 15 |
Made in Ukraine 4 channel class D power amplifier, rated power 350W per channel into 4 ohms
Edited by Oldmaelstrom - 19 November 2010 at 4:13pm |
Wrighty
Old Croc Joined: 17 April 2004 Location: Devon Status: Offline Points: 1801 |
I think I know where the inspiration for that front panel design came from...
ALL YOUR BASS ARE BELONG TO US.
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4936 |
Have a look at this amp and tell me your thoughts! amptop by Electro Mechanic, on Flickr Edited by kedwardsleisure - 06 November 2017 at 8:12pm |
North Staffordshire |
M4trix
Registered User Joined: 23 June 2009 Location: Croatia Status: Offline Points: 445 |
Enjoy repairing that wreckage. Probably you will need to replace the PCB too unless you wanna make wire jumpers over the damaged copper tracks. That PCB looks really nasty.
ceharden
The 10,000 Points Club Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11775 |
I suspect after a good clean the damage won't look quite as bad. I'm curious what the amp is. I can't quite figure out the topology from those pics. Also I know one output stage is upside down compared with the other but they still don't look the same.
DjLeco
Young Croc Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 817 |
ClassH 2 step!
Failed AB part from it, maybe oversized fuses, or fake 2SA 2SC output devices, the one wich burnt the 2 watts resistor are OPENED emitter, leaving the tension to chain burning other components , because the fuses did not blew when output devices fails...
Is an classical class H2 step OVERVOLT failing!
Very Bad!
I Bet is CHINA ONE! Edited by DjLeco - 19 November 2010 at 11:08pm |
andyamp
Old Croc Joined: 21 July 2007 Location: United Kingdom Status: Offline Points: 2115 |
yep not mde in the EU
http://www.matrixamplification.com/ |
cilla.scope
Old Croc Legs all the way to her bottom.... Joined: 02 October 2009 Status: Offline Points: 2954 |
it looks to be a single channel of 5+5 devices on the left, plus 2 channels of 3+3 devices on the right, mirror split half way up the PCB on the right if you look.
PSU has different raisl left and right side of the amp, I would guess the right side is 2 channels at a lower voltage than the left. just noticed its 5 DC supplies wires to each channel ... so theres a bit of rail switching going on Clearly purpose built as a 3CH, so most likely bass, mid, top from some sort 3 way box ... .looks too old/crap to be off a powered line array box .. Edited by cilla.scope - 20 November 2010 at 12:53am |
My girlfriend thinks I'm a stalker.
Well, she's not exactly my girlfriend yet ... |
Louder than loud
Old Croc Joined: 13 May 2010 Location: Guildford Status: Offline Points: 2377 |
i'll post a mackie swa amp up that went bang the other day lol ;)
swannie
Registered User Joined: 15 March 2008 Location: WEYMOUTH Status: Offline Points: 276 |
Rauch P-120 |
ceharden
Going back to the unnamed strange amp, I think Cilla has cracked it. Well spotted there.
Dilbert
Registered User Joined: 03 February 2010 Location: Northwich Status: Offline Points: 109 |
deleted.... just looked closer is this 3 channel? left hand side extra fan cooled bass & 2 x mid / tops on right with less cooling? Edited by Dilbert - 20 November 2010 at 1:00pm |
