Amp Internals 2 |
Post Reply | Page <1 206207208209210 260> |
Author | ||||
suiluj
Registered User Joined: 28 November 2007 Location: Phil/Singapore Status: Offline Points: 202 |
Definitely need one with this weight but a two man lift can do.
BooM BASSTIK EleCtronics and Communications Engineer
Live in harmony with one another. Do not be proud, but be willing to associate with people of low position. Do not be conceited. |
suiluj
Military AMP 100Kgs. 2steps H, 150-80-0-80-150
suiluj
suiluj
LV = 80V HV =150V 100Kgs ready to rumble... with this Edited by suiluj - 27 March 2017 at 6:26pm |
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4936 |
who's going to carry that amp up a wet fire escape at 7pm on a cold saturday night when the venue refuses to let crew use the grand staircase?
North Staffordshire |
studio45
Old Croc Joined: 16 October 2007 Location: United Kingdom Status: Offline Points: 3860 |
SO theoretically...say 240 volt swing into 2 ohms.....28,800 watts? CRUMBS.
djeddie
So have we finally found an amp that can power a scoop properly???
Coat's on and I'm opening the door. |
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5171 |
With those rails, it is equivalent to the old Crest 10.001 Amplifier. It is good see someone design what they need when what is available to the masses do not fit their requirements. Best Regards, |
infrasound
Old Croc Joined: 13 May 2011 Location: Brizzle Status: Offline Points: 2276 |
It would be interesting to see the temperature difference between the front and rear devices...
I hope those fans are powerful!
suiluj
Guess you'll have to wait till morning when the sun goes up. This is custom build intended for battle of sounds only. |
suiluj
2 ohms will be no problem. if weight is not an issue this amp will definitely punish scoop drivers. How about Class TD sounds good to you? Rail supply voltage = +/- 220VDC 16 pcs ELNA Capacitors, 4 bridge rectifiers 2 pcs front fans, 2 pcs rear fans Still on testing mode, will post some pics later Edited by suiluj - 30 March 2017 at 11:09am |
suiluj
