  New Posts New Posts RSS Feed - Amp Internals 2
Amp Internals 2
 Post Reply Post Reply Page  <1 6364656667 96>
Centauri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Centauri Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 12:44am
Would suggest NOT using stooorage.com as an image host on a public forum - some may not appreciate the advertising that goes with this domain........
Dub Specialist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2012 at 6:30pm
ive taken this pic from the 1st internal thread...im very curious about these Jts UA1 UA3 UA4 series of amps.
1..i allways under the impression tubbs built amps from stratch?? as his pre's-siren ect
2..it looks like another ca18 copy to me??
3..so what does tubbs do mod and beef these up??
4.so what amps are thay really?? (i know i ent gonna get that answer as it a soundsystem secret ting LOL) im not tyring to expose my mans works or anythink just if i was to buy one what am i getting?? simple
Edited by Dub Specialist - 03 June 2012 at 6:34pm
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2012 at 6:38pm
Should be simple to go through 40-50 pics and find it.. LOL
U.Viktor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2012 at 7:42pm
-I see Unreliable FASTON connectors (release by itself)
-I see the capacitors are physically separated from the amplifier = design FAIL
-the heatsinks could have pretty high gradient (one end is 30-40C more hot than the cold end)
-I see output wires to the connector (probably the feedback runs from the amp board) = Low damping
:) thats it
infrasound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2012 at 7:58pm
Yes, yes, yes, ?
Why the problem with output wires? Given the 5m+ to drivers, is 15cm an issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2012 at 8:32pm
Every millimeters is an issue especially together with capacitor to amplifier wires :-/
Not only the small milliOhms resistance but some of the additional inductance matters.
Added Foil caps to the amp stages would not replace a properly designed busbar structure
This is why NEXO Systems has usually four wires interfacing 2 power + 2 sense wires
SBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SBC Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2012 at 9:03pm
since when do faston become unlatched by themselves?
used thousands of the things, never had one come unlatched by itself.
Edited by SBC - 03 June 2012 at 9:04pm
F.T.S.S.
SBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SBC Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2012 at 9:05pm
spoken of recently on here too...
F.T.S.S.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2012 at 10:24pm
People have to sometimes put 10M extensions on speaker cables, due to unexpected venue issues, so no need  ring alarms about few cm in the amp... LOL
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2012 at 8:44pm
www.dss-audio.co.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2012 at 9:24pm
QSC PL 9.0?
I like the caps directly on the end stage power devices!
lost eden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost eden Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2012 at 9:24pm
QSC PL9?
web department
