Amp suggestions |
Post Reply | Page <1234> |
toastyghost
PAP told me that they'd be available in mid-June for about £1500 last time I called. Not sure how concrete that is. I'm very, very tempted by an FFA 8.0 but it's still not going to give 8 ohm loaded bins more than 1.2kw. In fact, none of the suggested amps so far do although I appreciate the help. Perhaps I'm just being too picky? Walt, is there really that much of an improvement when running the Punishers with 1500w each or more? It sounds right because the Looneys we use currently came alive the moment I gave them a QSC RMX4050HD per pair in 4 ohm bridged... it's looking like I might have to keep the 8 ohm drivers as spares and get 4 ohm ones to do this properly. Edited by toastyghost - 09 May 2007 at 11:34pm |
Disco Stu
Old Croc Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2487 |
Power compression will prevent powers of over 500W making a huge difference to the output - this recent quote from Bill Fitzmaurice says it well
"Generally with lower powered drivers xmax is the main limiting factor, as you don't get a huge amount of heat with a 200 watt driver. As power goes up so does heat, and it will become more of a factor. My point is that once you get beyond 500 watts if one factor isn't at work the other is, though it's more likely that both are. That doesn't mean you should avoid using drivers rated at more than 500 watts, just that you shouldn't count on getting any more out of one with 1,000 watts than you will with 500, and that being the case there's no valid reason to risk damaging the driver by driving it to full power."
So yes I would say you are being too picky - if you havent got enough volume you need more cabs not more amps.
Stu
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
Rog
New Member Rogers Archive Posts Joined: 23 March 2010 Status: Offline Points: 2166 |
Here's a pic of the first off the production line.
Should be on the streets in about 10 days time.
Rog. Edited by Rog Mogale - 10 May 2007 at 12:07pm |
Tekasis
Old Croc Joined: 03 July 2006 Status: Offline Points: 6492 |
Cheers Rog - Handles too
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
If you don't have the £2k plus for a decent lightweight high power amp, you're amp rack is gonna be heavy for a while. QSC 4050HD does not have good rep for sub Bass. Crest 8001/Qsc MX3000a/EV P3000 all give approx 3200W @ 4ohm bridge.The QSC is approx £500 used, 8001/P3000 upto £750 used I have a Proline 2700 that has same O/P as above amps but is allegedly Chinese. It has 3 year warranty from Thomann, Costs only £350 new, and is shocking in bridge mode. |
COWFOOT
Registered User Joined: 26 September 2005 Status: Offline Points: 1088 |
The Infinite 8 look wicked fi true.
norty303
If you're after some second hand PLX3402's, you might like to send Dom a PM as i think he may have some available.
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
How about the Proel PSW2600, which is 1300 a side into 4 ohms. digital and only weighs 12kg Have a look here for the spec:- There's a deal on them at the moment, pm me if interested.
Tekasis
It's meant to sound wicked to according to the specs & the vigorous testing Rog's done with it, so you know Iration Steppas will be looking to do his own testing.
Once this amp touches the streets, in a few months afterwards, I think they'll be loads of amps around up for sale at good prices to be able to get these.
toastyghost
Weight isn't a major issue, I just don't want to have 100kg plus just for the bass when I get more bins. It's a toss up between a pair of PLX3402s or the new Infinite 8. The specs on Void's site are very tempting as the one amp will happily do 6 Punishers at 8 ohms and I like the idea of the protection circuit. It's just whether the price is right and I'm willing to be an early adopter. Thanks for the tipoff about Dom, I'll see what he's doing with the 3402s before I make my decision. |
Tekasis
Slightly over 1500 ToastyGhost, £1586.00 from PAP hopefully by 25th May. maybe due to the 2007 budget.
Bryan M
Old Croc Joined: 17 July 2004 Location: England/Belgium Status: Offline Points: 2223 |
If anyones intersted i had the kryo 8s out the other day for a little test drive. As i really wanted to know what the amp was capable of i ran both sides at 2 ohms, hanging 4 sykos off one side and 2 stasys 8 off the other. I was really warry of it lasting the duration but i couldn't let that hold me back as i really wanted to be sure they are 2 ohm stable!
All i can say is wow, really nice sub coming out the sykos (even though they were under powered) and really tight speed bass coming from the 8's. It really changed my mind on using switch mode cabs on bass.
The amp got a little warm over the night but i think that was due to the ambient temperature of the club (sweat was pouring off the ceiling)
not sure if they will give you the required 1500w per cab but well worth a look in my opinion mate as they aren't too expensive either
