  New Posts New Posts RSS Feed - Androids susceptible to HeartBleed
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Topic: Androids susceptible to HeartBleed
    Posted: 23 April 2014 at 5:27pm
http://www.digitaltrends.com/mobile/list-of-android-phones-vulnerable-to-heartbleed-bug/#!FDNuL">http://www.digitaltrends.com/mobile/list-of-android-phones-vulnerable-to-heartbleed-bug/#!FDNuL
Launched With
Update Available?
Advice
Asus PadFoneAndroid 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
Asus PadFone 2Android 4.1PossiblyDANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
HTC One SAndroid 4.0Yes, to 4.1.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
HTC One X Android 4.0Yes, to 4.1 DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
HTC One XLAndroid 4.0Yes, to 4.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
HTC Evo 4G LTEAndroid 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
HTC Desire XAndroid 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
HTC One X+Android 4.1Possibly DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
LG Optimus L5Android 4.0Possibly NOT VULNERABLE (PROBABLY), CHECK VERSION
LG Optimus L7Android 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
LG Optimus L7Android 4.0Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
LG Optimus Vu (LG Intuition)Android 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
LG Optimus 4X HDAndroid 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
LG Optimus GAndroid 4.0Yes, to 4.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Motorola Atrix HDAndroid 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
Motorola Droid 4Android 2.3Yes, to 4.0 (or higher)NOT VULNERABLE (PROBABLY), CHECK VERSION
Motorola Droid RazrAndroid 2.3Yes, to 4.0 (or higher) NOT VULNERABLE (PROBABLY), CHECK VERSION
Motorola Droid Razr MaxxAndroid 2.3Yes, to 4.0 (or higher) NOT VULNERABLE (PROBABLY), CHECK VERSION
Motorola Droid Razr IAndroid 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
Motorola Droid Razr HDAndroid 4.1PossiblyDANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Panasonic ElugaAndroid 4.0UnlikelyNOT VULNERABLE (PROBABLY), CHECK VERSION
Samsung Nexus S (Google)Android 2.3Yes, to 4.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Galaxy Mini 2Android 2.3Yes, to 4.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Galaxy Ace PlusAndroid 2.3Yes, to 4.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Galaxy Ace 2Android 2.3Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Samsung Galaxy W (i8150)Android 2.3Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Samsung Galaxy ChatAndroid 4.0Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Samsung Galaxy NexusAndroid 4.0Yes, to 4.3NOT VULNERABLE (PROBABLY), CHECK VERSION
Samsung Galaxy S DuoAndroid 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
Samsung Galaxy S Advance (i9070)Android 2.3Yes, to 4.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Galaxy S2Android 2.3Yes, to 4.1 or 4.2DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Galaxy S3 (Non-LTE)Android 4.0Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Samsung Galaxy S3 (LTE)Android 4.1.1Yes, to 4.1.2DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Galaxy NoteAndroid 2.3Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Samsung Galaxy Note 2Android 4.1PossiblyDANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Galaxy S3 MiniAndroid 4.1.2PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia TipoAndroid 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia MiroAndroid 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia EAndroid 4.1PossiblyDANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Sony Xperia GoAndroid 2.3PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia SolaAndroid 2.3Yes, to 4.0 (or higher)NOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia UAndroid 2.3Yes, to 4.0 (or higher)NOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia PAndroid 2.3Yes, to 4.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Sony Xperia Ion LTEAndroid 2.3Yes, to 4.0 (or higher)NOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia Acro SAndroid 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia SAndroid 2.3Yes, to 4.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Sony Xperia SLAndroid 4.0Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia JAndroid 4.0Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia VAndroid 4.0Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia TAndroid 4.0Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Sony Xperia ZAndroid 4.1Yes, to 4.2.2DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Sony Xperia ZLAndroid 4.1Yes, to 4.2.2DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Sony Xperia ZRAndroid 4.1Yes, to 4.2.2DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Sony Xperia Z UltraAndroid 4.1Yes, to 4.2.2DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Sony Xperia SPAndroid 4.1Yes, to 4.3DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Android tablets that could be vulnerable to Heartbleed
These are tablets span across carriers and countries. It’s not a complete list. We’ve mostly tackled only the big manufacturers. Let us know of omissions by commenting.
 Launched WithUpdate available?Advice
Acer Iconia A700Android 4.0Yes, to 4.1.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Acer Iconia A110Android 4.1PossiblyDANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Asus Transformer Prime (TF201)Android 4.0Yes, to 4.1.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Asus Transformer Pad 300Android 4.0Yes, to 4.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Asus Transformer Pad InfinityAndroid 4.0Yes, to 4.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Asus FonePadAndroid 4.1PossiblyDANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Cube U30GT 2Android 4.1.1Yes, to 4.2.2DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
HP Slate 7Android 4.1.1Yes, to 4.2.2DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Lenovo A2109Android 4.0.4Yes, to 4.1.1DO NOT UPDATE, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Galaxy Tab 2 7.0Android 4.0Yes, to 4.2.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Samsung Galaxy Tab 2 10.1Android 4.0Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Samsung Galaxy Note 10.1Android 4.0Yes, to 4.1.2NOT VULNERABLE (PROBABLY), CHECK VERSION
Toshiba Excite 10″Android 4.0Yes, 4.1.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
AT&T phones on sale now that could be vulnerable to Heartbleed
Launched With
Update Available?
Advice
Samsung Galaxy S3 MiniAndroid 4.1.1Yes, Version 4.2DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Galaxy Note 2Android 4.1.1 Yes, 4.3DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
T-Mobile phones on sale now that could be vulnerable to Heartbleed
Launched With
Update Available?
Advice
HTC One SAndroid 4.0Yes, Version 4.1.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Galaxy Note 2Android 4.1.1 Yes, Version 4.3DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Verizon phones on sale now that could be vulnerable to Heartbleed
Verizon
Launched with
Update Available?
STATUS
Samsung Galaxy Note 2Android 4.1.1Yes, Version 4.3DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Kyocera Hydro EliteAndroid 4.1Not that we know ofDANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
LG EnactAndroid 4.1.2 Not that we know ofNOT VULNERABLE (PROBABLY), CHECK VERSION
Casio G’zOne CommandoAndroid 4.1.2 Not that we know ofNOT VULNERABLE (PROBABLY), CHECK VERSION
Droid Razr MAndroid 4.1Not that we know ofDANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
LG Spectrum (Used)Android 2.3 No NOT VULNERABLE, BUT YOU NEED A NEW PHONE
LG Revolution (Used) Android 2.2 No NOT VULNERABLE, BUT YOU NEED A NEW PHONE
Sprint phones on sale now that could be vulnerable to Heartbleed
Launched with
Update Available?
Advice
Samsung Galaxy Note 2Android 4.14.4.2 in late AprilDANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Galaxy S3Android 4.1Yes, Version 4.3DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Motorola Photon QAndroid 4.1Yes, Version 4.3DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
LG Viper (new and used)Android 4.0PossiblyNOT VULNERABLE (PROBABLY), CHECK VERSION
Kyocera Hydro EdgeAndroid 4.1 Not that we know ofDANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
HTC EVOAndroid 4.1Yes, Version 4.3DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Kyocera TorqueAndroid 4.1 Yes, Version 4.1.2DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Samsung Replenish (Used)Android 2.2NoNOT VULNERABLE, BUT YOU NEED A NEW PHONE
Samsung Epic 4G (Used)Android 2.3NoNOT VULNERABLE, BUT YOU NEED A NEW PHONE
Nexus S 4GAndroid 4.0Yes, Version 4.1DANGER! IF RUNNING 4.1.1, REMOVE SENSITIVE DATA, AVOID WEB
Edited by levyte357- - 23 April 2014 at 5:31pm
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 5:34pm
The preppers where right, the world is comming to an end...
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 24 April 2014 at 9:03am
Nothing quite so dramatic..
Just software update, or change of phone needed.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 24 April 2014 at 10:20am
nobody's heard of my phone, but it's got 4.04... only one mention of that on your list there, "Lenovo A2109     Android 4.0.4     Yes, to 4.1.1     DO NOT UPDATE, REMOVE SENSITIVE DATA, AVOID WEB"
hmm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 24 April 2014 at 10:25am
hmm.
Basically saying... Released with 4.0.4, which is OK, up-datable to 4.1.1.
If you have updated to 4.1.1, "Trouble".
My Galaxy Ace 2 has 2.3.6, which is fine.
Been considering un-official update to 4.1.1, guess what, not now.. LOL
Will wait for upgrade in July, methinks.
Edited by levyte357- - 24 April 2014 at 10:27am
Adam_Iron_Horse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Posted: 24 April 2014 at 3:43pm
So am I okay on 4.2.1?
Don't see my phone there but its a lenovo p780?
Kryptonik Sound Kollective
www.facebook.com/kryptoniksoundkollective
Post Options Post Options   Thanks (1) Thanks(1)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 24 April 2014 at 4:01pm
Yep.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Posted: 24 April 2014 at 6:39pm
Cheers man!
This page was generated in 0.483 seconds.
