Any dual 18" ported designs that are 90cm wide? |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
Posted: 06 May 2011 at 2:12pm |
I realise that the drivers themselves are that size already so will need some form of V baffle loading or push/pull style mounting. I was wondering if there are plans already? Does a V baffle make any changes to the sound? I was going to build a 400ltr box for the XB/Primes. Is it also possible that the V baffle and the port might interfere with eachother? |
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
Build it push-pull with one behind the other (Logic Systems style) if it needs to be 90cm wide I reckon.
SamV
How's that compare output wise?
Jez_3phaze
Registered User Joined: 31 August 2009 Location: Derby UK Status: Offline Points: 162 |
Have you set your mind on V sub?
How about a 218 manifold.
Beyma 25-9 (76.7 x 57.4 x 71.2) or EV MTL2 Just over at (91.4 x 57.2 x 76.2)
SamV
I like reflex, it's the most versatile loading in my opinion.
VentureSound
Young Croc Joined: 18 October 2009 Location: London N20 Status: Offline Points: 950 |
Do it push-pull like Meat says, its the same output as a dual reflex but lower distortion, which can only be a good thing.
specialjustin
Young Croc Joined: 18 November 2006 Status: Offline Points: 555 |
I don't disagree, but if it's the case why doesn't everybody do it that way?
Teunos
Because it's more work and requires just a little more thinking. Also you lose a good few liters as half of the baffle has to be sat back something like 25cm
But totally worth the effort i.m.o.
Best regards,
Teun. |
ceharden
If you make it a shallow V shape then it'll make very little difference at all.
Depending on how wide you intend to make the cab, you might be able to offset the drivers to each side of the baffle and squeeze them in on a the flat. However that might only work with round framed drivers and not the squarer Fane ones. |
