  New Posts New Posts RSS Feed - Anyone used Sae pcm20 @2ohm
jonezy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonezy Quote  Post ReplyReply Direct Link To This Post Topic: Anyone used Sae pcm20 @2ohm
    Posted: 01 March 2017 at 5:00pm
Like the title says has anyone used sae pcm amplifiers @ 2ohm or even 2.6ohm? Did it like it? I'm powering 4 v18 1000's off of a pcm20 at the moment and it never goes near the clip .Upgrading to 6 in the next month and then 8 next winter.When i go to 8 i was thinking of powering 8 hd15's from the pcm if possible & getting a k20 or similar for bass.
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2017 at 5:24pm
pcm18s went thermal after a while when we tried 3 BR cabs pCH, dont know if pcm20 copes better..
Instead of "putting all eggs in one basket" i would go for 2 amps as its much more versatile and safe (not that k20 are known to blow up) + gives more bass array options depending on dsp channels.
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2017 at 12:17pm
What he said..
Cheap way to run 8x HD15s, would be 2x used SAE PXM1450.
EDIT:If PCM 20 gives all you need in terms of Sub over 4x cabs, another PCM 20 for driving next 4x subs, surely must be considered.
What subs do you have/music genre do you play?
Edited by levyte357- - 02 March 2017 at 12:22pm
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2017 at 12:34pm
just wondered if anyone has tried  a pxm1450 v a pcm20,pure curious + 1 on what lev says...genre????,if it can run driver on edge and not clip sounds like a winner,
Edited by paulus - 02 March 2017 at 12:34pm
secret is in the expansion!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonezy Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2017 at 3:06pm
I have 4 hogs & it's mostly jungle/dnb/dubstep/grime/reggae that it gets used for.I'm happy with the performance of the pcm so will probably just get another one.I have a Pxm850 i use on mids and compression that I'm happy with aswell.I'm using an old crest 8001 on the hd's and my dsp is a dbmark xca28.
Edited by jonezy - 02 March 2017 at 3:07pm
