APEX2181 |
Post Reply | Page <1 1819202122 27> |
apexaudio
Registered User Joined: 22 September 2010 Status: Offline Points: 210 |
Yes but I made active x-over with EQ for this subs, look at similar HK Projector sub it range is from 40Hz to 160Hz without EQ in active x-over. Edited by apexaudio - 08 June 2017 at 11:16pm |
Mile Slavkovic
apexaudio
APEX Active X-Over for BH18 with low-cut, boost EQ, Limiter...
Mile Slavkovic
apexaudio
APEX Acive X-Over for TT110...
Mile Slavkovic
_djk_
I used to use multiples of a clone of the Klipsch LaScala (a similar sized horn)
I built 24 of them. The LaScala it basically a 100hz horn, Klipsch claimed it was ±5dB in a room to 45hz. A block of four was usable to 42hz with some EQ. Hornresp shows a single being a direct radiator (a big woofer in a small sealed box) below about 90hz. Gray is K33 (the hi-fi driver), black is the K43 (the PA driver). One K43 in a vented LaScala type box, about 7dB more output in the 40hz range. Sims done with 2.83V in 2Pi, drivers are nominal 4Ω types. A single has very impressive bass when used with a 35hz Q=2 filter in a typical room. EV Interface A EQ box at top left of photo, BMS Co-Ax for mids and HF on a custom made wooden elliptical horn. In room raw response in gray, with a digital room EQ in blue. Edited by _djk_ - 08 June 2017 at 11:59pm |
djk
apexaudio
T215
Mile Slavkovic
bob4
looks like an upscaled Q7
apexaudio
Or K24
Mile Slavkovic
apexaudio
Thanks(1)
Edited by apexaudio - 18 July 2017 at 5:21pm |
Mile Slavkovic
apexaudio
Mile Slavkovic
mini-mad
I've got the same thing on paper waiting for room in my lockup for a mock up.
apexaudio
Mile Slavkovic
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 515 |
A+
