  New Posts New Posts RSS Feed - "Baltic Birch" alternatives for new build?
DemonKnight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DemonKnight Quote  Post ReplyReply Direct Link To This Post Topic: "Baltic Birch" alternatives for new build?
    Posted: 21 October 2016 at 12:16pm
So the build calls for "Baltic Birch"  I just looked at the 3/4" x 4' x 8' Baltic Birch Plywood and it seems it's a special order product by my location and it's almost $70 a sheet plus shipping whatever they will try to charge me for that too! Can I get away with these 2 options or any other recommendations in the Chicago land area?
Here's what's available locally at Menards
3/4" x 4' x 8' UV Prefinished Birch Plywood (13 ply $45 )
This plywood features a clear, thick semi-gloss epoxy acrylate finish and a four coat ultra violet coating system.
  • Ultra violet cured for extra durability
  • CARB 2 compliant and SEFA 8.0 certified
  • Great for cabinet boxes, store fixtures
  • Nominal size
  • Hardwood plywood
  • Factory applied 4 coat UV-cured finish 2 sides
Dimensions: 3/4" x 4' x 8'
Shipping Dimensions: 96.0 H x 48.0 W x 0.75 D
Shipping Weight: 63.0 lbs
Brand Name: Shelter Forest International
Or
3/4" Classic Birch Plywood - Wood Veneer Core (13 ply $40)
This plywood features a C grade white birch face with .25mm face thickness and a 3 grade birch back. This plywood is sanded birch.
  • 18mm thickness with a .5mm tolerance
  • 11-Ply, with calibrated Poplar core, moisture controlled for stability
  • Veneer core
  • Sanded two sides
  • Great for crafts
  • Hardwood plywood
What do you guys think? Thanks in advance!
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2016 at 10:41pm
Spend the $70 a sheet (I buy from Menards).
'C' has knots in the wood (junk).
djk
