Baracuda Pre-Amps & Power Amps |
Post Reply | Page <123 |
Tekasis
Old Croc Joined: 03 July 2006 Status: Offline Points: 6492 |
mskeete
Registered User Joined: 10 June 2004 Location: United Kingdom Status: Offline Points: 920 |
not completely sure how that was done I've always prefered amps that played flat and full range.
The one that I have is strictly bass even if you feed it a full range signal
He filtered the input at around 100Hz
I'd have to have a closer look (got a 2k piece siting in the 'museum' but no time) but I think that switch also adjusted the switching frequency of the main amp
sliverr
Registered User Joined: 17 April 2007 Status: Offline Points: 61 |
error
Edited by sliverr - 05 January 2008 at 1:19pm |
Tekasis
What's happened to the owner of the Baracuda amp above ''Sliverr'' ? All I can see is error everywhere he has posted!
**Heavy Weight-Line**
A home without books is like a body with no soul. |
championdrei
Registered User Joined: 28 September 2011 Status: Offline Points: 119 |
I never play my amps on full, to me it just gets louder and the bass sounds harder and the sound loses that sweet sound to it.
Learn how to control your sound via the Control tower... Once you master this, you'll hear the difference. My Amps are usually quater of the way up, not even half and it fill up big hall and stuff same way with some heavy b line. Its not about power to me it's. About how you play your set and the quality of it. I've gone dance with little 500w amp playing bass and kill sound with it running 3000w. Nowadays to me all sound man think of is power and how loud the sound can get, seen nuff sound running like 1 Amp per box and stuff, it's. All not needed imo coming like people forget how to play sound. To me sounds used to sound better back in the days than they do now. As for the barracuda tops when you say hissing are you talking about the knob just under the tops switch? Fazer knob. To me barracuda has the crisses tops I've ever heard you just need to know how to play it. Every other pre amp maker to me their tops sound like normal tops but when you hear barracuda his tops have a different sound to it |
respect
bob4
yes that's a difficult point to explain..... Friend of mine had his amps turned to "11". Problem was that the signal from his preamp (forgot which builder, one of the big name UK man) was too hot. He couldn't turn the bass output control on the preamp past 9 o clock Eventually they decided to turn the power amp gain controls down +22 dBu is 10V innit? |
