Barricuda Pre Amp |
Post Reply | Page 123 6> |
cuttinraza
Registered User Joined: 19 August 2014 Location: Marlborough Status: Offline Points: 107 |
Posted: 22 July 2016 at 7:25pm |
Greeting all jus picked up a barricuda mk1 pre amp wana post pic but dunno how to from i fone??
Any help with the mass of knobs on the front?? Is it true that this fella taught jah tubby how to build his range?? Thanks in advance 🇬🇳🙏👊 |
King Simeon
Young Croc Joined: 13 January 2007 Location: United Kingdom Status: Offline Points: 788 |
In a word: NO I hope you didn't buy something you don't know how to use..? There are a few different models, but I think the main volume control is on upper left side. Eq usually along the bottom sometimes over to the right, usually 10 band or 12. There's quite a bit of technical in the way the gain controls are and how they work with cut offs. Sometimes 2x bass controls, though usually only one works at a time. A pic would be handy, and input from Barracuda pre amp users/owners.
https://www.facebook.com/KingSimeonSound?ref=stream
https://soundcloud.com/king-simeon |
cuttinraza
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Offline Points: 770 |
Does it all work correctly?? And how much did you pay?
Reverence Sound system
cuttinraza
I gave 550 for it, seems much better than the tubby's
one in my opinion!! 🇬🇳🙏 |
cuttinraza
cuttinraza
dj jammin
That all looks fairly standard and correct..
cuttinraza
King Simeon
Wow,, you've done well to get the diagrams etc. The Tubbys looks pretty old too, has it had a service..?
The Barricuda sounds much better when playing old tunes, the tops are pretty strong, but I found it didn't do so well on the modern sounding tunes. Pots probably need some re-knewing on both if aged, but a nice set of old time pre's you got there. |
dj jammin
A few ive seen have had phono sockets on the back, (maybe added on) also see you got the jack socket for bass slider on the diagram, couldnt see it in the photo. Does anyone use this feature anymore??
streekz
Registered User Joined: 12 February 2008 Location: United Kingdom Status: Offline Points: 110 |
hope this helps Edited by streekz - 23 July 2016 at 12:47pm |
