Barricuda Pre Amp |
Post Reply | Page <12345 6> |
cuttinraza
Registered User Joined: 19 August 2014 Location: Marlborough Status: Offline Points: 107 |
Wats a bass slider?? |
streekz
Registered User Joined: 12 February 2008 Location: United Kingdom Status: Offline Points: 110 |
i took ours to be serviced due to various ppl in the sound having it through its life and wasnt sure what was working, the guy who looked at it found out it had been fiddled about with from original spec which is why i have that photo layout to show the change
cuttinraza
Kool, ill have to play arround an work fings out then....... |
cuttinraza
It works! Wat a wicked sound seems like the next level! Few problems wiv the pots tho as most importantly the bottom two mid treb sweeps sound like the musik underwater. Guna strip it down an intensely clean em tom.............
Roll on tom eve ....... Jah |
streekz
aint nothing play like barracuda
cuttinraza
Yeh Man! Cleaned all pots an works like a dream now the phazer brings out the tops like summin else!! 😊😊😊😊😊 The sends are sends an not wat the diagram i got says which is an echo...... Any other hidden features?? The 3 way kill for the phaser i think needs replacing as i can kill the phaser an bring it back in....... Unless thats the way it works?????? Thanks for all ur help bro..... Im blown away by the dept of bass using the bass hardener. My tubbys is now surplace but not for sale!!!! |
cuttinraza
Oh yeh can u use any of the inputs for a mixer signal?? Im using the third gain below the mid kill!!?? Bless |
streekz
not on ours if you look at the description text in photo channel one is a phono only connection using red n white phonos the other two channels are both line and phono but can only connect either line or phono not both together and are connected via "Y" phono leads to sum your twin phono leads to one
the tops phaser may operate the same as ours there is a description about it in photo text also Edited by streekz - 26 July 2016 at 7:02pm |
p-ranx
Registered User Joined: 30 October 2011 Location: london Status: Offline Points: 17 |
I have the same Barracuda pre amp , had it since 1991 still works fine could do with a couple of pots replaced but still going well , iam looking to get a mostec as its the nearest thing to a Barry pre amp
p-ranx
https://youtu.be/_bOsuD_D4JY - https://youtu.be/_bOsuD_D4JY clip on youtube testing out a G-Sub I was building , heavy sound .
p-ranx
true words , had mine for years and still going strong
cuttinraza
Yo Ras, I noticed u using the send gain to echo the music...... Have u got a delay in the chain so u get that effect?? Blesz |
