  New Posts New Posts RSS Feed - Battle of the scoop kick bins
 Post Reply Post Reply Page  <12345 10>
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 10:34am
Originally posted by bitzo bitzo wrote:
what about folded horn for kick on scoops?
15's or 18's ?
If 18's, which you reckon would be better sounding above scoops! 186's or 1850's ?
Originally posted by YoungBlood YoungBlood wrote:
Didnt mention ES18BPH as 2x on their side is too wide for scoops, and I personally think it is too high standing up.
Would you say these folded horns above some RX18's in the below pic are too narrow for the scoops ? Wink
**Heavy Weight-Line**
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 10:41am
Static you're cheating mate !!!
Those scoops are a little wider than most, and there is a little gap in between them...
However set does look very neat.
Edited by levyte357 - 02 December 2008 at 10:41am
(SoundcreationaudiO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote (SoundcreationaudiO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 10:45am
what about some of these....
boldsystems seems well happy with them...  18"  bandpass horn kick bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 10:58am
Seems a bit huge mate.
I guess the ideal would be USB size, with ES18 performance, which wont happen, unless custom driver is used.
Do people think 2x18 reflex with PD186/XB/Celestion would out do HD215 with PD154 @ 70-180 inside and out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote (SoundcreationaudiO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 11:02am
think the size is 552 wide, 580high, 750mm deep...  grills with 20mm foam fronts
YoungBlood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote YoungBlood Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 11:09am
Much thanks for all the feedback.
Seems finances will be choosing which cab I go with, as it must be usable as sub with smaller gigs as well.
So I guess I'm going for Gsubs or 1x18 cubes. Probably loaded with PD186/XB/18PS100.
Thanks again people.
"chyll wynstan.."
billso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote billso Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 11:45am
[/QUOTE]
HD215 would be 3 - 5 db louder in that pass band.
Static Age View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 12:07pm
The scoops are quite wide. The gap is caused because those scoops are pretty much flightcased & they have fittings on the sides which alow them to interlock when stacking.
Dub Defector View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Defector Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 2:31pm
 i was thinking the same thing and people had some opinions here:
Rough Every Time... http://www.dubselector.co.uk
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 3:27pm
15's or 18's ?
folded horn with 15' path lenght 100 cm
18' are reserved for scoops ;)
Edited by bitzo - 02 December 2008 at 3:28pm
smithers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smithers Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2008 at 1:08pm
i'd take the pepsi challange against most kick bins with my Pd186 loaded ES18's. 600mm wide to stack nice and neat on top of our Hogs.
we used to own a G sub which we used over our scoops, and i'm confident in saying 1 ES18 would destroy a double 18 G sub @ 80-180hz easily
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2008 at 7:54pm
