  New Posts New Posts RSS Feed - B&C Sub18 Build pics
 Post Reply Post Reply Page  <1 9101112>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2016 at 5:35pm
Thanks Bee!
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2016 at 5:46pm
dug these pics out....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2016 at 11:43am
Ah wkd Bee , look very nice cabs , pro man
thanks bro
boots-hifi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2016 at 12:02pm
Slighty off subjuct but ive gota pair of Q18's loaded with the recomended BMS drivers for sale. Designed by Tony Wilkes and built by bee they look very similar to those sub 18's but are more compact and have a better output both in terms of frequency response and SPL. Pm me if anyones interested.
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2016 at 7:56pm
Ben text me what you wanted, ill possibly buy em back... Gonna need 8 for a small project. Saves me building another 8...
Foca_Dacian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foca_Dacian Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2016 at 10:52am
How does the B&C SUB18 sound in terms of musicality and how high can I run it?( I have build 155 liters reflex subs tuned to 45 hz with FaitalPro 18FH510 and I'm happy with the overall sound)
I am now planing on building 4 x B&C SUB18s with FaitalPro 18HP1010-4 ohm version (very similar TS with B&C-s 18TBX100 recomended for this plan.
Question is:what major differences will be between the smaller 155 liter box and the b&c sub 18 plan?
Crashpc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2016 at 6:51pm
18TBX100 in large box sounds like herd of stomping elephants :-)
sub218 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sub218 Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2017 at 8:51am
To Crashpc: do you mean that in a positive of negative way?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2017 at 9:40pm
Subwoofers are supposed to do that in herds, so yes, very positive. These can do a lot!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2017 at 12:01pm
Marketing is why many are brainwashed into thinking a small enclosure will offer the same performance as a large enclosure when using an 18-inch woofer.
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2017 at 4:41pm
That is very broad statement, both true and false at once.
If the speaker cannot fully exploit capabilities of the box due to the low performance of "itself", then it might happen that smaller system could do the same as larger system. Product lines are wide, from low-end to hi-tech...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2017 at 5:23pm
There is nothing false about it. The name of the game is to sell as many products as possible. If it takes using a two smaller enclosures in order to achieve the same response in terms of performance using one larger enclosure, so be it. Such marketing tactics has been going on for 30 years...
Take in consideration those who walk around with pink pocket books crying about size and weight, they are a marketers dream.
Best Regards,
Edited by Elliot Thompson - 11 January 2017 at 5:32pm
