Best 15" midwoofer for 2way direct radiation P.A |
Page 123> |
Fiore_89
Topic: Best 15" midwoofer for 2way direct radiation P.APosted: 21 February 2012 at 1:37am |
Hi, guys!
I plan to build a 2way ( 15" midwoofer + 1,4" HF driver ) for P.A use. I need a light loudspeaker with flat frequency response but also with good sensibility in order to use it with a 18" reflex subwoofer. What is the BEST midwoofer for this solution? I'm thinking about 18Sound 15NMB420.... Thanks. |
SamV
Joined: 21 October 2008 Location: London Status: Offline Points: 5006 |
Posted: 21 February 2012 at 2:19am |
The best would be Volt or ATC, neither do light models though.
Radiance Audio http://www.radianceaudio.co.uk | Bikeology http://www.bikeology.net
meister_gue
Joined: 01 October 2010 Location: Austria Status: Offline Points: 32 |
Posted: 21 February 2012 at 10:36am |
Beyma 15P80Nd! Not cheap, but a really great driver!
Tony Wilkes
Joined: 02 August 2004 Location: West Midlands Status: Offline Points: 3346 |
Posted: 21 February 2012 at 10:41am |
There is no best 15" driver just a list of suitable candidates that would suit. I personally would look for one aimed more for upper bass use with a light cone and probably a 3" voicecoil, power is going to be around 500w max.
All of the major quality manufacturers make something suitable. Unfortunately the only real way to tell if it suits your ears is to have a listen. The Beyma above although it has a 4" voicecoil does look like suitable candidate. Tony Edited by Tony Wilkes - 21 February 2012 at 10:43am |
www.forteaudio.eu - BMS - db-Mark Processors
Meat
Joined: 05 June 2009 Location: France Status: Offline Points: 801 |
Posted: 21 February 2012 at 10:43am |
PDN15BR40 gets a good review. Not used it myself though.
biotec
Joined: 07 June 2004 Location: United Kingdom Status: Offline Points: 2627 |
Posted: 21 February 2012 at 11:58am |
rcf mb15n401 is nice
Earplug
Joined: 03 January 2012 Location: Europe Status: Offline Points: 693 |
Posted: 21 February 2012 at 12:22pm |
Best usually depends on your budget...
_djk_
Joined: 23 November 2004 Location: United States Status: Online Points: 3755 |
Posted: 21 February 2012 at 1:09pm |
Not lightweight, about $275 in the USA:
![]() TD15M - 4ohm Fs: 34.7Hz Qms: 5.09 Vas: 312L Cms: .3mm/N Mms: 70g Rms: 3kg/s Xmax: 6mm Sd: 855sqcm Qes: .35 Re: 2.9ohm Le: .15mH Z: 4ohm Bl: 11.25Tm Pe: 500W Qts: .33 1W SPL: 97.8dB 2.83V: 102.1dB |
djk
lickweed
Joined: 02 May 2009 Location: leyton Status: Offline Points: 1276 |
Posted: 21 February 2012 at 1:23pm |
jbl 2227h,although they are discontinued,but very good mid 15"
My laptop is 24h on,when im log in dosn't mean im by computer!!!
kevin tyler
Joined: 15 April 2007 Location: Spain Status: Offline Points: 1691 |
Posted: 21 February 2012 at 1:34pm |
sorry to drift a bit
i'm running a jbl 2226 with a b&c de75 2" bi amped and crossing at 1,2khz, is there any reason to cross lower? kev
lickweed
Posted: 21 February 2012 at 2:33pm |
I wouldn't cross lower,in fact higher but don't think 2226 will go higher.
Edited by lickweed - 21 February 2012 at 2:33pm |
kevin tyler
Posted: 21 February 2012 at 3:30pm |
yes i figured it might be the case, they are only my back up gear anyway, but i tempted to go the gym and use them more.
Page 123> |
Tweet
