best horn design for 100-300hz |
Post Reply | Page 12> |
Eskae
New Member Joined: 13 November 2013 Status: Offline Points: 3 |
Posted: 13 November 2013 at 11:42am |
I use Turbosound Floodlight tops, which roll off around 300hz, and Turbosound 21" subs that dont sound that great above 120hz.
What's a good horn for the 100-300hz range that has design plans available. thanks
djeddie
The Holy Grail...
but have a look for Martin Audio 215 MKIII. They're designed to go to 250Hz, but will play higher. |
QSS
Old Croc Joined: 21 July 2009 Location: Bristol UK Status: Offline Points: 2414 |
Thunderridge SB1000
Ah sorry! Just noticed the last part of original post. No plans available for these. Edited by QSS - 13 November 2013 at 8:29pm |
"Music is life"
Eskae
Funktion One recommended their F215MKII ( http://www.funktion-one.com/products/f215-mk2/), not having access to this speaker I got some F215MKIs instead( http://www.funktion-one.com/products/f215/). I thought it would work since it seems like the same design but having the drivers firing towards each other instead of side by side, but they ended up sounding poor above 120hz.
Yesterday though I discovered the Turbosound TSE215, which seems like the same design as the F215MKII, which would probably work right? ftp://ftp.turbosound.com/datasheets/legacy_products/tse115.pdf And apparently the HD15 is a copy of the TSE215 also? But i'm still skeptical if any of these design would work if the F215MKI didn't, unless there is a huge difference in horn flare or something that would make the F215MKII and TSE215 superior for upper bass over the F215MKI.
Edited by Eskae - 13 November 2013 at 10:45pm |
soundforyou
Registered User Joined: 14 June 2011 Location: Ireland Status: Offline Points: 299 |
I agree, Any of the martin horns 115, 215mk1, 2, 3, will go to 300hz. suitable drivers:- ATC PA100-375 blc RCF L15 - 554k RCF L15 N401 PD 153 ER PD 154 P Audio C15 - 500LF 18 Sound 15LW1400 PHL 6030 B&C 15 NA 100 B&C 15 NW 100 B&C 15PL 100 JBL 2227 Beyma 15P 8OND Beyma 15GT 200 |
Life is Now
Subliminal
Registered User Joined: 25 February 2012 Location: Bath/Bristol Status: Offline Points: 279 |
I thought the Turbosound Floodlight played down to 180hz or am i mistaken?
We used to run ASS BS500 with original Fane Studio Colossus drivers in to meet our ASS MX350 tops at 200hz and they sounded lovely! Edited by Subliminal - 14 November 2013 at 3:09pm |
Soundwave
Registered User Joined: 04 May 2010 Location: Banbury Status: Offline Points: 118 |
TSE118's with the right drivers will play 100-250 quite happily, I'm on the look out for some TSE115's as I'm certain these will perform event better. The key to these boxes playing high is not just the horn flare, but the driver they are loaded with.
Monkeys
Registered User Joined: 30 August 2012 Location: Melbourne - Aus Status: Offline Points: 429 |
I also thought the floodlights played down to 180hz, at least that's what the specs say? Maybe the ones the OP is using aren't the original drivers or something?
The MKB230 goes alright up to about 230hz before it starts to sound honky. Would be sufficient to meet the flashlights I reckon. |
njw
Your right to be skeptical, HDs start sounding honky past about 150hz IMO.
Neurosub
Registered User Joined: 22 December 2010 Location: Canada Status: Offline Points: 23 |
I can attest - I have 2x HD215 and I def dont have them play above 150hz.
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
Would you consider reflex?
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
You need to talk to Rich Dangernoise...
Straight 12 or 15 with a very long horn with a big mouth. Conceivably you could built something that folded round the back of the 21s so the overhang isn't too bad. |
