Best Horn for a line array project |
csijo
Registered User Joined: 28 March 2005 Location: Venezuela Status: Offline Points: 102 |
Posted: 07 January 2011 at 11:34pm |
Hi Guys.. I am about to start my new build, is for 4 or 8 speakers line array type but i'm just a little in doubt what is better to make it..To get more spl and sum and align the sound of the boxes what horn is better the pyle nexo clone the dayton wave guide or build the horn with wood in the box i will apreciate the help of the specialistes yours. Thanks
The links for the Horns and drivers are here:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=270-314 http://www.parts-express.com/pe/showdetl.cfm?Partnumber=292-2576#windowcontent http://www.parts-express.com/pe/showdetl.cfm?Partnumber=292-2546#windowcontent http://www.parts-express.com/pe/showdetl.cfm?Partnumber=292-2504 http://www.pyleaudio.com/itemdetail.asp?model=PDS122 http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-442 |
Audio Fanatics, Bass lover
mk2_ginger_biscuit69
none of them will array properly...
csijo
I understand but here in venezuela we no have for sale line array horns,
so i want to know what of th 2 options will be better. Thanks
NONE
pfly
Might sound harsh but ginge is right.
http://bmsspeakers.com/cone-speaker-compression-driver/neodymium-compression-drivers/bms-neodymium-planarwave-drivers/bms-4510nd-planar-wave-driver/4510nd-planar-wave-introduction/ http://profesional.beyma.com/ingles/pdf/TPL150.pdf These with basic "horizontal" wooden waveguides built in front of them and stacked on top of each other with minimum vertical clearance would probably behave pretty much right. Problem is, you'd still need to get mid drivers within 10cm apart from each other for them to behave correctly. |
csijo
These Horns are wonderful but here in Venezuela this is not achieved here we have a exchange control of annual purchases only allows for 400 dollars and if these products were achieved in Venezuela would be super extremely high costs. The current government of Venezuela is a communist and Venezuelans do not want us to use dollars.
It's possible to get some plans to build a wooden trumpet which meets the specifications to behave as a line array? |
if you cant make a trumpet array properly which you cant with the parts you have available, then build point source (normal 'large' box) speakers which will the same thing as you would end up with but actually work properly.
csijo
I really appreciate your help do not know how I appreciate it.
My idea is to make 8 boxes same but I'll start making 4 first because I have now only the 8 midbass eminence the idea of stacking them and fly them in a truss could better explain it to a point source? Thanks |
