Best suited box for 18Sound 15MB1000 Speaker? |
Post Reply | Page 12> |
Richie narine
Registered User Joined: 18 May 2016 Location: Guyana Status: Offline Points: 15 |
Posted: 18 June 2017 at 7:06pm |
Looking for best suited box for 18Sound 15MB1000 speaker?
Keen
Young Croc Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1203 |
check for the X15 in the plans section
Richie narine
Thanks for the reply...The X15 is a horn loaded box...I prefer a box that is just for the speaker...
djeddie
The X15 is a reflex box, NOT horn loaded. Yes it has a horn in it, but that is for HF.
Richie narine
Ok...thanks for the info....
Richie narine
Is it possible to just use the speaker alone in the box?
cravings
you just want a bass speaker?
what do you want it for? more information will help people suggest things to you. |
Richie narine
I want it for low mids/mid bass...
darkmatter
You might get better responses if you give more info. E.g. what bass cabinets you'll be using them with, what mid-hi cabs, what amps, the frequency range (in Hz) that you're hoping to cover.
Yes you could make the X15 and simply cover up the hole where the high frequency horn would go. You may need to reduce the internal volume to compensate for the space that would have been taken up by the A HF horn. However you probably don't want a trapezoidal box for this application anyway, so it'd probably be better to make a rectangular box that replicates the internal volume and port length / area of the X15 if that's the sort of thing you want. Edited by darkmatter - 20 June 2017 at 10:21am |
Richie narine
I want a box for the 18sound 15MB1000 speaker....I have a QSC RMXA4050 power amplifier and a DBX 260 DRIVERACK ....looking to play between 40hz to 60hz...Hoping to used two speakers in one box....roughly 100liters internal volume...
Edited by Richie narine - 20 June 2017 at 10:58am |
darkmatter
40 - 60 Hz is an incredibly narrow frequency range and would normally be described as 'bass' rather than low mids / mid bass. What speakers are you using above and below i.e. what subs and what high frequency speakers?
I suspect you probably want something like this: http://www.forum.poweraudio.ro/viewtopic.php?f=92&t=9948 You would need to adjust the internal volume and port dimensions to suit the drivers, you can use software such as WinISD or Hornresp to model this using the Thiele / Small (t/s) parameters of the driver.
Richie narine
@ Darkmatter...thanks....This is the design i am looking for....www.forum.poweraudio.ro/viewtopic.php?f=92&t=9948...I am using two of the same 18sound 15mb1000
In one box... |
