Betapacks sound like washing machines |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
Posted: 01 August 2014 at 9:09pm |
Hey all,
For the past month I've had 5 betapacks installed at my place, running off a 3ph32 supply and controlled by a Leapfrog. Everything is running safely within it's limits and the actual draw is tiny, maybe no more than 2kw across the phases at any one time. After 3 weeks of working perfectly, the other day they starting making a weird noise after powerup, that is to say it sounds like a washing machine on a slow cycle ie not a constant drone. The mains meters fine, the distro says all is fine, the betapacks look happy and everything works as it should except this loud noise. Increase or decreasing the load makes no difference and we've even repatched to no avail. Any ideas? |
burningbush
Old Croc Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5897 |
Loose coil or transformer somewhere?
norty303
burningbush
James Tengo
Old Croc Joined: 09 May 2008 Location: Brighton Status: Offline Points: 2155 |
Which version of the betapack? Is it one of them or all of them?
SamV
Never had a chance to unplug and find if it was all or just one but the whole lot being stripped out now anyways. Unsure which version it was.
