Beyma SB18 building pics |
Post Reply | Page 123 11> |
pope
Registered User Joined: 03 February 2006 Location: Sweden Status: Offline Points: 121 |
Posted: 04 January 2010 at 10:39pm |
Hello!
I am building two Beyma SB18 with Beyma 18P1200Nd. The material is 18 mm scandinavian birch. I hope to be finished in a week or two.
ackeepeg
Registered User Joined: 02 May 2009 Location: Jamaica Status: Offline Points: 45 |
Looking really nice so far.
audioalliance
Registered User Joined: 10 July 2007 Location: Trinidad and Tobago Status: Offline Points: 144 |
nice build... what are you running them with?
http://www.myspace.com/audioalliance
music is our mission |
MarjanM
I would really like to know how this boxes will sound. Very easy build.
audioalliance
Yeah I second that... Hit us up as soon a s you test 'em....
login4
Old Croc Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
i third that, iv found myself thinking about this design allot,
keep us posted.
CELTIC SUBSONIC SOUND SYSTEMS
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
I presume that is a fabric "grill" for protecting the driver? what is the material? I assume this is for home use (or similar non aggresive venue!) |
pope
Stainless steel net 1 mm thick with 65% open area. Light venues only :-) |
pope
First cab nearly finished. I will tomorrow make a test and compare the SB18 with a Punisher loaded with Ciare 12.00 SW.
pope
I made a test this evening and used a QSC PLX 3402 as amplifier for subs and a Crown XS 4300 for EV SX 300. I connected a Beyma SB18 and a Punisher to the QSC on each channel (700w at 8 ohm) and from 30-120Hz.
The room was a bit small (4x8 m). The difference was not so great between the subs! The sound was equally high with a good kick in both subs but the SB18 sounded better at the lowest frequencies (30-50 Hz)
audioalliance
hmmm.... I wonder how those cabs compare outdoors... any chance of this happening... thanks alot pope, you're a boss
fredos666
Registered User Joined: 11 October 2008 Status: Offline Points: 205 |
We built dual one...A pair outside per side ( equal to 4 SB18 each side) driven with 1500W each (driver) kick at 100 foot easy. Bottom are great, no need for extra sub. We did an arena this NYE with 4 double each side and this was enought for 6000 peoples...130 db in the middle of the crowd in ''C''...Pretty impressive for the size...We load them with RCF 18N401...Easy to get here. We measure 6mm of excurtion in one side, seem to be the same when driver kick inside..Just made some RTA this afternoon, will try to post it tomorow..
