Beyma SB18 building pics |
Post Reply | Page <1 678910 11> |
MrSolito
New Member Joined: 14 December 2010 Status: Offline Points: 6 |
thanks !
I'm planning to build 2 sb18's with beyma 18p1000nd driver.
I will use 18mm birchply but i thought it would still be necessary to support because of the power this enclosure will have to handle with ?
I'm still looking for some building pic's because i'm interested in ways of construction because of the angled construction of the interior.
Ohw very interesting..! Do you know if any other 18inch eminence speakers would do just fine?
Thanks alot !
MrSolito
Pope, one little (probably stupid) question:
The dimensions in the CAD file are in mm but they're accurate to 1/100 of a mm.
Is there any file with 'sawable' dimensions or may I just round to mm's ?
I'm now adding some more dimensions and corners to the CAD file so I can start making my sawplan end of the week.
pope
Registered User Joined: 03 February 2006 Location: Sweden Status: Offline Points: 121 |
1/100 mm! I got the sheets of birchply pre cut at my local lumberyard. 1 mm is OK! It´s not rockets we are building. . I used one side of the cab an draw a 1/1 sketch where all pieces should come. I think this is the most easiest way to get all angles correct if you don´t have a CNC tool of course. I´m using a Festool circlesaw with a ruler
CHAMPION
Old Croc Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3667 |
similar design to the EV T-18 and SB180
Sticks n Stones
MrSolito
First building pics ! Prepared speakermounting and handles. The first plate is glued and screwed to one side. More pics when cab is finished
Edited by MrSolito - 07 January 2011 at 1:06am |
MrSolito
One cab finished a few days ago, next cab will be ready in a few weeks.
Last building pics and finished pictures of sb18
Greetz!
Only have to fix the grill, foam is already cut at size
login4
Old Croc Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
very neat build, would love to hear some of these one day.
CELTIC SUBSONIC SOUND SYSTEMS
MrSolito
tested my 2 new sb18 cabs with beyma 18P1000nd driver.
Not yet powered at max, my current strongest amplifier can only handle about 600watts/8ohm /channel.
Going to check out some Amcrons MA1200 next week, they would do just fine in bridge mode. 980 watts/amplifier so 1 amplifier for each cab.
However, I tested them at somewhere around 600 watts this weekend...
When standing in front of the cab, it's like a windturbine and definitely really nice bass !
audioalliance
Registered User Joined: 10 July 2007 Location: Trinidad and Tobago Status: Offline Points: 144 |
great look my friend.... hope you love the sound of the sb18's as much as i do...
http://www.myspace.com/audioalliance
music is our mission |
moyojojo
New Member Joined: 25 May 2011 Status: Offline Points: 8 |
Hi. What about 18P1000Fe in SB18? |
daywalk3r
Registered User Joined: 12 August 2010 Location: Earth Status: Offline Points: 180 |
Sims almost exactly like the 18P1200, even cone displacement per watt. The rear chamber volume difference due to different magnets will probably also has negligible effect on the final result. Though the 18P1000Fe has a somewhat lower x-max and 200W less power handling, but it should be fine if not pushed hard and high-passed properly (roughly @35-40Hz). |
JuliOLT
Registered User Joined: 17 May 2010 Location: Lithuania Status: Offline Points: 26 |
Just tried to build one of these with 18P1200Nd. First impression was "WTF? this enclosure didn't sounds any like peoples said in this topic" there was lack of low's while played some dubstep (before i used 18P1200Nd in vented box, which played down to ~30Hz). The things are changed when tried to play some house or techno music, especial when i walk about 40m away :) then i get impressed, still no lower than 40Hz but it kicks real nice and the sound presure were realy higher compare to vented enclosure. Now im going to build 2nd enclosure to try... if it fits to me, then i'll put vented away :) Maybe anyone measured how low can go 2 or 4 SB18's? Thanx
