Beyma TD-245 discontinued! What to use instead? |
Post Reply | Page 12> |
Tarkovsky
Young Croc Joined: 30 June 2011 Location: Limehouse (LDN) Status: Offline Points: 513 |
Posted: 11 November 2011 at 5:07pm |
Really excited over our punisher/xtro build. One of several annoying little problems frustrating my Xtro build. We already have puns in the shop is this buisiness over the Beyma TD-245 being discontinued. Well, we only have 1 ciare 12 sw atm because they're out of stock over here and they're expensive in the land formerly know as Europe. A few other questions I had regarding the Xtros Anyone got any cad files for them? Which wire to use insides? Anyone know a cheap place to get the xt8 horns... online they're £130 now... I know that tri-lithium crystals inside the drivers have shot up in value, but plastic is ****ing plastic! Anyone selling any drivers or unfinished projects? What are the exact delay times everyones? Thanks! Zak Edited by Tarkovsky - 11 November 2011 at 5:24pm |
godge
Young Croc Joined: 07 July 2010 Location: Gloucestershire Status: Offline Points: 597 |
Yeah they have been for a while now, think I got the last two from bluearan as well earlier this year
Tarkovsky
Yeah they seem to be the cheapest supplier. I ordered a single ciare 12sw off of them, they're out of stock till the new year.
On the td245 sureley there must be an equivalent part as people still buy and use the drivers that go with. Anyone know how to get in contact with the designers? Maybe they can help. |
ceharden
At the moment the XT8 horns are only available from Bluearan. If they were plastic then then maybe they'd be cheaper but they're made from high quality fibreglass, the phase plug is strengthened with steel rods in the arms and it comes complete with a back bowl. So not that expensive for a drop-in solution with higher performance than the original Xtro wooden flare.
Regarding the TD245, there aren't many 60x40 1" horn flares available on the market, especially compact ones. It was quite a specialist one. Partly because to get 60x40 dispersion control properly you really need a larger mouth. How about: http://www.bluearan.co.uk/index.php?id=BMATD164&browsemode=category or http://www.bluearan.co.uk/index.php?id=FTPFPLTH102&browsemode=category |
Tarkovsky
That's excellent thank you. Thanks for the info. I'm an absolute novice in speaker building.
Tarkovsky
phildat
Young Croc Joined: 29 January 2009 Location: manchester Status: Offline Points: 1115 |
rcf hf64
http://www.ebay.co.uk/itm/RCF-HF64-1-1-4-Horn-Flare-with-adaptor-/200631199666?pt=UK_ConElec_SpeakersPASystems_RL&hash=item2eb68d27b2 good horns. |
Its just a ride.
ceharden
RCF is starting to get a bit on the big side. You don't want to be blocking up the entire output from the upper 15" driver.
el_dj
Registered User Joined: 30 November 2007 Location: Denmark Status: Offline Points: 176 |
Thanks(1)
sorry about this little off topic thing
what is the opinion about this one |
Old twat, with an interest in light & sound
ceharden
Being exponential, it won't have a consistant frequency response over it's coverage angle. It's also quite small so probably only useful from about 2.5kHz upwards. Probably good for use with 8" drivers in compact cabs.
Tarkovsky
This horn looks right:
http://www.bluearan.co.uk/index.php?id=BMATD164&browsemode=category Anyone know how much modification will be required of the xtro to get it to fit? Also, if the td-245 should suddenly become available, and I built two more xtros, would they place nice together? |
ceharden
The 164 is probably Beymas replacement for the 245, I wouldn't expect it to become available except second hand.
