  New Posts New Posts RSS Feed - Bloom on TuffCab Castors
SouthwestCNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Topic: Bloom on TuffCab Castors
    Posted: 17 May 2017 at 3:23pm
One month out of packaging on cab in a container. Had I known they do this id have sprayed with ptfe. Do you guys do anything to yours? Anyone know is this will brush off with a copper wire brush say?
Edited by SouthwestCNC - 17 May 2017 at 3:29pm
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 3:29pm
The ones I got from thomann last year still look like new, salt spray?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 3:32pm
Salt spray? There may be salt in the air as we are by the sea. But you would have thought it would take more than a month to attack them. I have plenty of galvanised bits in the workshop that have been here years and as new.
edit... Just checked some other galvanised brackets that are in the container, also fine.
Edited by SouthwestCNC - 17 May 2017 at 3:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 3:34pm
Got this on a total of 48 castors!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 3:49pm
Not galvanised that's why just very poorly electro plated. Don't take your cabs anywhere near a seaside town.
WILLZTHRILLZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WILLZTHRILLZ Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 4:04pm
HI, could you strip them into separate parts leaving the bearings alone and find someone near you with a small blast cabinet that does powder coating or stuff like that and just paint em with heavy zinc primer?
I live in a seaside town too, so know yer problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 4:06pm
That is a PITA, maybe worth giving them a bell?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 4:13pm
They will all have to go back to blue aran. They are not fit for purpose imo, and no warnings is supplied with them and no mention in regards to only being stored at certain humidity's in the product description. I'm sure id have seen this before if this were the case for all electro plated parts on say tools for instance.
Edited by SouthwestCNC - 17 May 2017 at 4:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 4:16pm
Anyone know of a better quality castor than tuffcab?
spongebob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 4:20pm
Adam hall
Jimmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimmer Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 4:24pm
Pen Elcom
Light travels faster than sound....That's why some people appear bright until you hear them speak!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 4:29pm
Thanks will have a look.. Have you guys seen this with either the pen elcom or adam hall castors?
