BMS 12 c262 enclosure suggestions |
Augusts
Registered User Joined: 07 January 2017 Status: Offline Points: 180 |
Posted: 07 January 2017 at 11:35am |
Hi all
This is my first post here :) I would like to hear your opinions on this - what type of enclosure would you suggest for this driver the BMS 12 c262 coaxial? In a small sealed box xcrossed at 200hz they output max spl. Someone suggested a Karlson enclosure to get it to play the lower notes <70 hz The other way would be forget everything below 200hz and maybe add a small horn to get the sensitivity up a little 200-1800 is that possible for this driver? What do you think? Thanks Have a good day! August
JaKe
Young Croc Joined: 14 September 2007 Location: N.E. Wales Status: Offline Points: 684 |
From BMS:
Recommended reflex enclosure: 14 L / 68 Hz, -3 dB = 86 Hz, BRD = 70 mm / 109 mm long 25 L / 63 Hz, -3 dB = 70 Hz, BRD = 80 mm / 78 mm long |
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
this driver is best used in things like wedge monitors ect.
Augusts
The 14L rephlex should be limited to 150watts. that is 118 db. 400w would be 122db. not much but still..
