  New Posts New Posts RSS Feed - BMS 18N850V2 vs Void 1200
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Topic: BMS 18N850V2 vs Void 1200
    Posted: 09 February 2011 at 12:24pm
Has anyone compared these two in a Hog or other scoop? They have rather similar parameters if you ignore the fact that the BMS has a 4" voicecoil.
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2011 at 2:52pm
Rog designed the V1200 as a dedicated scoop driver, don't think the same can be said ior the BMS
not saying the BMS is bad, far from it
didn't think you could get v1200's anymore?
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2011 at 3:19pm
We have run 850's in Smithers hogs. Also done a nice tapped horn for the 850 :)
The 850 has the better cooling and build quality whether it sounds better than the 1200 is down to personal choice, I thought that the 850,s sounded smoother and less aggressive but as I am totally biased not a very fair comparison.
Tony
