bms 4595ND driver perameters |
SouthwestCNC
Posted: 04 February 2017 at 1:28pm |
Any one know where I can find the driver parameters for the bms 4595 ND? TIA
Teunos
Parameters???
Best regards,
Teun. |
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
specs for the driver are on there website if that's what you need
if im not mistaken they were used by ohm in many models and from memory I think they were crossosed over at 1200hz pasi would be able to help you further with this
GOD TOLD ME TO DO IT !!!!!
odc04r
Are you after Thiele Small parameters? Presumably to design a horn flare? It won't work in quite the same was as modelling low frequency designs, a lot of things change with regards to air loading and standing wave resonances etc as you go up in frequency. Assumptions about how waves travel are no longer often the case.
If you search threads relating to Unity Horns on DiyAudio I think there were some TS parameters posted for various BMS compression driver models. With compression drivers you also have to consider that TS parameters will not help a lot, because the enclosure is essentially already there for you. The analog to a driver is the diaphragm, which inside a compression driver is already mounted with front/rear volumes, phase plug and mouth. What you have to design is the horn flare that couples it to free air loading efficiently and gives the dispersion you want. |
