Boombox/case build finished!! |
Post Reply | Page <1234> |
Shortrope
Hey...I'm not really the man to help with your power supply questions as I'm no expert and I've been learning as I go. You'll need a relay that switches between the battery and mains, there's quite a bit of info about this in my Boomcase build thread. As far as having the input on one 3.5mm jack goes, you'll need a switched jack which will turn off the Bluetooth module when you plug in. Again, I'm no expert but I know this is how other folks do it and hopefully they'll post up here.
Shortrope
Thanks man...the kids love em alright and they're used a lot!! I've got to eliminate the interference when charging an iPod off them though, it's the only problem with them.
roubi
Registered User Joined: 14 June 2012 Status: Offline Points: 39 |
Neutrik NTE 4
Edd Jordan
Young Croc Joined: 10 January 2008 Location: United Kingdom Status: Offline Points: 1364 |
[/QUOTE] Thanks man...the kids love em alright and they're used a lot!! I've got to eliminate the interference when charging an iPod off them though, it's the only problem with them. [/QUOTE]
You need one of these http://www.bluearan.co.uk/index.php?id=MON064370&browsemode=category |
Shortrope
Ahhh...cool! I was wondering if one of those would do the trick.
Edd Jordan
should do only realy helps if your 5v power for the iphono isnt putting crazy amounts of noise into the earth. i use them on my projects alot they do the job when using a 12v car cigarette lighter charger and they kick out some noise!
iboominate
New Member Joined: 29 September 2013 Location: Costa Rica Status: Offline Points: 9 |
What relay did you use exactly im searching and i see lots of types ?
can you give me a diagram of the wiring you did ? i cant tell much by the pictures , just a simple handwritten one will suffice thanks
iboominate
found some info , i still cant tell what specific relay is used but at least i know the type now heres the link for other ppl haing same q`s as me http://forum.speakerplans.com/tips-for-kids-boom-build-please_topic83577_page2.?KW=relay - http://forum.speakerplans.com/tips-for-kids-boombox-build-please_topic83577_page2.html?KW=relay
lutkeveld
The Neutrik increases the signal, which isn't necessary if the gain is set properly. In that case you could just get a groundloop jsolator on ebay for a couple of bucks. Essentially it's just a 1:1 input trafo.
iboominate
Lutkeveld could you help me out ? i have no idea how to wire my rig up by using shortropes same power anc charging setup! i just need a basic scheme to follow and what relay to use and how to wire it up ive learned alot by searching but i still havent (think ) found a suitable relay .
I tried following the picture but wires are still confusing |
lutkeveld
If you could give all your goals and details I'll make a schematic when I'm home this afternoon.
But IIRC Shortrope already drew a schematic which in his other 'questions thread'. Have a look. Edited by lutkeveld - 02 May 2014 at 1:00pm |
Shortrope
