Boominator build (UK)... |
Post Reply | Page <1 678910 11> |
slaz
Got a couple of panels of Hexlite here - different shapes, but about 2m^2 in total.
Density is (I think) about 80Kg/m^3 ..... similar to balsa wood methinks. Looking forward to making a box of some sort from this - although I suspect a conventional ply baffle would be reqd, as cutting/machining the stuff is not so possible. |
DJ-Dulux
Registered User Joined: 24 August 2009 Location: Kenilworth, UK Status: Online Points: 379 |
No idea then, we can not find an error... Will check again, although not sure what else is left.
Dupe... |
Dupe...
Saturnus
Old Croc Joined: 13 July 2010 Location: Copenhagen Status: Offline Points: 2025 |
Let's review
Fronts are 2x900x300mm = 0.54m2 Top/Bottom are 2x276x900mm = 0.4968m2 Braces are 2x393x276mm = 0.216936m2 Ends/Internals are 4x276x276mm = 0.307404m2 Handle/Ports are 2x96x276 = 0.052992m2 So total wood needed is 1.614132m2 The cut outs are Woofers 4x222mmØ = 0.154830m2 Tweeters 4x76mmØ = 0.018146m2 Brace diffuser 20x62mmØ = 0.090572m2 Ports and vents 8x66mmØ = 0.02737m2 Port slits 2*96*62mm = 0.011904m2 Access cuts 2x156x66mm = 0.020592m2 Cut out total is 0.323381m2. That's 1/5th... how did I get it to 1/3rd.... hmm Anyway... that's total of 1,290751m2 times the average 11.8mm thickness is 0,0152308618m3 and 10.7834501544kgs if the WISA numbers are correct. But mine was demonstrative lighter so the weights numbers given by WISA must be incorrect. Granted I did use stored WISA FORM that probably has a significantly lower humidity than factory fresh sheets so that may account for it.
WesleyK
Registered User Joined: 24 December 2012 Status: Offline Points: 90 |
I might be able to put mine on a scale this weekend. If I remove the electronics module its pretty much only the plywood + speakers. Should give us a rough idea of the weight of the wood (after substracting the weight of the speakers ofc)
Shortrope
Ye won't care how much it weighs once you hear it!!
DJ-Dulux
Thanks for the information, it seems to confirm that our calcs are correct. Our model with wisa birch is at just over 11kg, we have used 12mm thickness as this is the mean thickness, tolerance is 12mm +- 0.5mm, we also have 2 shelves in the battery location. Therefore our prediction and your calculation look about right. 11kg verses 10.8kg? Thanks for the support, was beginning to worry that we had made a big error in the design... Dupe... |
Dupe...
DJ-Dulux
I am getting excited now, already got an event lined up.... Baby rave in the local park.... Dupe... |
Dupe...
DJ-Dulux
Wisa ply is not easy to get in UK, therefore I am looking at SyPly, its a slightly lower spec at 665kg/m^3. Does anyone have any experience with it?
Dupe...
Dupe...
Saturnus
I doubt there's much difference between reputable manufacturers. WISA is just the most well known.
DJ-Dulux
That was my feeling also, although looking at the spec sheets wisa is marginally better... Dupe.... |
Dupe...
DJ-Dulux
Just been looking at post #5882 on the DIYaudio Boominator thread and a different port configuration is suggested for the Basslite drivers. Not seen this mentioned before:
120mm wide 40mm high 24mm deep (2 ply layers) 40mm rounds on ends of slot Standard is: 120mm wide 30mm high 36mm deep (3 ply layers) 30mm rounds on ends of slot How does this change the set up, I could re-work to the 30mm high still, anyone compared? Dupe...
Dupe...
Gavos
Registered User Joined: 15 June 2013 Location: out there Status: Offline Points: 59 |
