Boominator MINI (development thread) |
Post Reply | Page <1 4748495051 102> |
bassplar
New Member Joined: 24 March 2014 Status: Offline Points: 3 |
Been trying to get the dimensions for the box down, but it seems sketchup isn't working or the links provided are broken. Any other way to view the dimensions and drawings?
WesleyK
Registered User Joined: 24 December 2012 Status: Offline Points: 90 |
Specs of your battery and power supply?
Are you sure the speakers are connected correctly? Do the tweeters have a filter? Edited by WesleyK - 24 March 2014 at 11:07am |
fred7847
Registered User Joined: 13 March 2014 Status: Offline Points: 16 |
Can anyone help me with a component-list for the crossovers? :)
lutkeveld
For the Monacor or Aura version?
Shortrope
Thanks(1)
dman_15
Registered User Joined: 26 July 2013 Status: Offline Points: 18 |
I'm using a 7ah 12 yuasa sla. The power supply is 12v 5a.
Its a standard build using the ns525's with the Dayton tweeters. Everything sounds as it should, with a frequency test the crossovers behave as you would expect, it's just the amp cutting out at max volume. What do you mean by filter on the tweeters? |
WesleyK
Hm, you're power supply/battery looks fine. Normally when a power supply or battery isn't able to supply the current you would expect the amplifier to cut out. Another option could be that you have somehow wired the woofers/tweeters wrong, so that the load drops <4 ohm. In that case the amp will probably shutdown (thermal protection). But a TA2024 or your amp with the right setup, should never cut out, unless the board has a clipping protection or something like that?
dman_15
I feel like a bit of a plonker now, rechecked the wiring and found the problem :( |
WesleyK
Great :)
Edited by WesleyK - 24 March 2014 at 6:13pm |
fred7847
For the Aurasound NS525-255-8A 5.25" Woofers and Dayton Audio ND16FA-6 5/8" tweeters with a TA2021-amp :) Thanks!
bassplar
Fred,
I am looking at these from parts-express for my cross-over also. I am a civil engineer so this may all be wrong, but I am trying. Maybe someone else here can tell me if I am on the right track with these. www.parts-express.com/jantzen-056mh-18-awg-air-core-inductor--255-232 www.parts-express.com/jantzen-022mh-18-awg-air-core-inductor--255-212 www.parts-express.com/audyn-cap-q4-22uf-400v-mkp-metalized-polypropylene-foil-crossover-capacitor--027-110 www.parts-express.com/audyn-cap-q4-56uf-400v-mkp-metalized-polypropylene-foil-crossover-capacitor--027-115 Sorry I could not get the hyperlinks to work. Tried a few times.
Edited by bassplar - 25 March 2014 at 3:27am |
fred7847
Thank you so much! I'll try to find to parts here in Denmark. For me, this is the hardest part :)
