Boominator MINI (development thread) |
Post Reply | Page <1 5253545556 102> |
Aterren
Registered User Joined: 14 July 2013 Status: Offline Points: 151 |
Looks great! I'd be interested in hearing a bit about how you did the grill.
dman_15
Registered User Joined: 26 July 2013 Status: Offline Points: 18 |
It's a standard enough build with ns525's and Dayton tweeters.
Amp was a eBay $20 job with the volume pot removed. Powered with 7.2ah SLA battery. I added a usb charge port so I can charge phones or mp3 players and that's about it really. Mounted inputs switches etc to a recessed dish on top. To do the speaker grille I made the top, bottom and side pieces 5mm larger all round which left the face with the speakers mounted in sitting recessed 5mm. Made a frame in 15mm x 5mm timber strip that sat into the recess flush. Then stretched & glued the fabric to the frame then the frame into the recess. Pretty chuffed how well it looks, surprised myself! Edited by dman_15 - 05 July 2014 at 5:12pm |
Aterren
And chuffed* you should be. How surprised were you by the sound? :)
*that is a lovely word. |
dtbingle
Registered User Joined: 09 September 2013 Location: USA Status: Offline Points: 27 |
Just a random question. My mini sounds great, but I'm thinking of rebuilding with a different, more durable appearance. How much does the shape of the box matter? For example, if I made it a bit less long, but a bit taller to keep the same volume, how much would this effect the output? Also, if I moved the tweeter from being centered vertically to the top corner, how much would this effect output?
Aterren
Saturnus has stated moving the tweeters off the centerline is detrimental to sound quality. He has also stated (in main boominator on the other site) that minor changes in dimensions should not have a big impact.
Ideally you can give us all an A vs B report, :) Edited by Aterren - 08 July 2014 at 3:09am |
dtbingle
Ahh thank you. I didn't read much through the main boominator thread, just this one haha. If there's ever time to test it out, I'll post back here with a comparison!
Aterren
That is very understandable. The main thread requires a real commitment. :)
dtbingle
Yeah 500+ pages takes some time haha. Do you happen to know how frequency response and volume vary from using the smaller monacor sp60/8 drivers opposed to the aura ns525s? EDIT: Or the difference between any other alternative driver that has popped up here. I have enough Aura ns525's to make another one, but if there is an alternative driver that can produce a better response (and keeping roughly the same size or smaller), then I'd go with those.
Edited by dtbingle - 08 July 2014 at 5:16pm |
Aterren
I have not built the SP60 mini yet so i cant comment on the sound quality. Saturnus has stated the SP60 is better optimized for indoor use. It is quite a lot smaller than the mini documented in this thread.
Edited by Aterren - 09 July 2014 at 11:08pm |
dtbingle
Does he talk about this SP60 build in THIS thread or somewhere else? Also, I'm curious if anyone has experimented with an external subwoofer that can connect to it. Such as build the smaller SP60 version and then if you want a little bit more low end make a separate subwoofer unit with its own amp/battery that can connect to the boombox. And obviously be disconnected for more boombox portability. EDIT: Also, is there any driver similar to the Monacor sp60 that can be used? USA here and it looks like it only is sold from UK
Edited by dtbingle - 12 July 2014 at 1:53am |
Aterren
The original (10" main driver) and SP60 design are both in the thread below. http://www.diyaudio.com/forums/-d/104402-boominator-another-stab-ultimate-party-machine-109.#post3988393 - http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine- http://www.diyaudio.com/forums/-d/104402-boominator-another-stab-ultimate-party-machine-109.#post3988393 - 109.html#post3988393 As for ordering...there are no great options in the USA, but I just ordered SP60 drivers from MaxAmp.nl for delivery to the USA. The shipping for 4 drivers and a MaxAmp will be ~25 Euro. |
Aterren
Sorry for the wonky link.
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-109.html#post3988393 |
