  New Posts New Posts RSS Feed - Box builders yellow glue
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Topic: Box builders yellow glue
    Posted: 12 April 2017 at 3:11pm
Done a few refurbs latley,
noticed some using that yellow expanding glue, i know gorrila glue does that
can you tell me please whats its called, and what your choice of glue is,
want to do some of my own testing tbh
thank you...
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 3:16pm
It is Polyeuthane (PU) glue.
Be aware you want gloves on (it stains hands VERY well) and water activates it so working time in a damp workshop is not too high...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 3:18pm
Big thanks manThumbs Up
nice to hear ya back bro......
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 3:34pm
Smile
I-shen Soundboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote I-shen Soundboy Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 4:05pm
The foaming property is a feature of thixotropic glues, which can come in both PU and PVA formulations.
I've only experience of PU thixotropic glues, both 30 and 5 minute set types (Everbuild Lumberjack). Titebond make a thixotropic PVA which might be worth a look.
You should wipe/dampen surfaces before applying to increase penetration and speed hardening.
Not that it needs any speeding up mind - I've been using 5 minute set stuff, and it really does: Everything has to be exact, dowelled and test assembled first, then I have 5 minutes to glue to all edges, assemble and whack tight with a mallet. Clamping can extend into the 30 minute curing/hardening window, but not by much.
Cup of tea later, box solid, next job.
You might want to start with the 30-minute set stuff, the 5 minute stuff is like using cyanoacrylic superglue, there's little margin for error, it has a grab time of seconds.
Edited by I-shen Soundboy - 12 April 2017 at 4:53pm
SouthwestCNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 4:51pm
Soudal is the best PU by far. Stuff like timbond and everbuild seem to more effected by cold weather and the stuff wont flow or go off. Soudal cleans off beautifully with the back of a chisel. Best Tip, Always buy in tubes never bottle, Just get yourself in a right old mess. Bottle are for first fix chippies house bashing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 5:03pm
And use sash clamps with thick cls timbers across both sides of box as it will push your joints apart.
Edited by SouthwestCNC - 12 April 2017 at 5:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote I-shen Soundboy Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 5:46pm
Ditto joint shear - the expanding glue can cause the joint to offset, often perpendicular to clamping
SouthwestCNC: Where do you get Soudal PU in tubes? Only ever seen it in bottles. If I'm only using it occasionally, tubes do keep fresher once opened. A half full bottle has a lot of air to cure with.
I agree with you on the everbond. I've been using some 3 year old tubes (12 month shelf life) and it doesn't flow as well as it did when fresh, but sticks just the same. They've been stored indoors mind - anything in a lockup over a long cold weekend is a different matter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 5:50pm
https://www.amazon.co.uk/Soudal-Purocol-Assembly-Adhesive-310-ml-Clear/dp/B007WFURZE/ref=sr_1_1?ie=UTF8&qid=1492015798&sr=8-1&keywords=soudal+purocol
You shouldn't pay as much as that tho ^
Or westward tool base is where I go.
putting the bottle or tube on a radiator helps it flow. the more yellow the pu the harder it is to clean off, the longer it takes to set and the set is softer I find. apart from being in a bottle another reason gorilla glue etc is not very good. soudal dries white and rock hard when bulging. In a tight joint its kinda clear.
Edited by SouthwestCNC - 12 April 2017 at 5:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote I-shen Soundboy Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 5:58pm
Ah, cheers. Was looking for pro45p in a tube; silly me 😝.
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 6:00pm
DEFINATELY go for the tubes rather than bottles. You look at the bottles and they seem a much better deal but by the time you're half way down it has thickened enough to make it a pain to squeeze out of the bottle. The tubes go in a standard mastic gun.
I have to confess I've never had any problems with the everbuild brand  and must have used close on 100 tubes of the stuff. As above the excess cleans off easily with a sharp chisel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2017 at 6:00pm
The purocol is a bit more advanced imo
This page was generated in 0.061 seconds.
