BSS Soundweb 9088 VS DCX2946 |
Grubbah
Old Croc Joined: 14 July 2011 Location: Portsmouth Status: Offline Points: 2014 |
Posted: 04 September 2013 at 12:53am |
Im thinking of the best option for my monitor rack..
I need to run at least 4 auxes, with the potential to run more... would like the option to run at least 4 auxes with bi-amped wedges or up to 6/8 auxes with passive wedges. Im currently have been using 2 x DCX2496s when i have to utilize more than 3 auxes. So i was thinking an 8 in 8 out would be ideal. The xcillia ive seen is way over budget for me atm, so i was considering the BSS soundweb 9088 Sound vs functionality vs budget vs space.. Realistically the rack will be untouched, only ever toured with me, mainly with the wedges run passively so being able to change DSP settings without a laptop isn't an issue... As ive never used the soundweb before, im wondering what people reckon will be a better option for my application? Cheers :) ** Also.... 9088... 9088ii ?? Edited by Grubbah - 04 September 2013 at 1:00am |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8707 |
If it never has to be touched then a soundweb sounds like a good idea :)
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4576 |
Joe - Go 9088ii or iis - there is an audible difference between those and the basic 9088.
Grubbah
Cheers Dylan! Confirmed my suspicions over a staggered price difference between the 2 models Are they quite simple to set up? Ive seen you use them in a couple of client custom racks |
ceharden
While I like the Soundwebs for installs where the flexibility is very useful, I would suggest that sticking with 2x DCX may be the better option. The Ultradrives definitely sound better than a 9088, big difference, maybe less between them and a 9088ii.
dylan-penguinmedia
For what you want to do with it, incredibly simple. Design a file, which maps out your signal path, from whichever input to whichever output, and drop in as much or as little processing as you require. It becomes more complicated when you need source selects, etc, but for a monitor rack, easy stuff. |
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
So in your opinion 9088ii is sonically inferior to behringer ultradrive? Any other opinions on this? Might be grabbing a 9088ii on the cheap - would be an upgrade at least outputwise (6 VS 8). [EDIT] sorry for being slightly off-topic..... Edited by bob4 - 05 September 2013 at 2:45pm |
ceharden
To be honest I haven't done a direct comparison between the 9088ii and the Ultradrive. The DCX definitely sounds better than the original 9088 and the 9088ii sounds better than the original. It's probably a tough call. If you need the extra outputs of the Soundweb then that will make the decision.
The DCX is always going to have the advantage of running at 96kHz whereas the Soundwebs are 48kHz. There are tricks to using the Soundwebs, such as the fact that the limiters built into the crossover modules are useless, use the dedicated limiters instead. |
lgosdset
Young Croc Joined: 28 September 2010 Location: Reading ish Status: Offline Points: 1203 |
soundwebs are great, have never had any complaints about sound quality, but I use iis. as long as you have a laptop handy, there is no issue with flexibility as you can make your own control panels, so they can be as user friendly as you like/be bothered to programme.
make up a decent patch panel tho, or have it permanently plumbed in, those phoenix connectors are a pain if you want to re-patch quickly. |
Djdarch
Old Croc Joined: 10 November 2005 Location: Newark, Notts Status: Offline Points: 1989 |
If you want a sound web why not go for the newer tec of the sound web blu series ? i have a blu 16 available at a reasonable cost . 8 in 8 out and the new blu range sounds incredible....
bob4
why not, if you can get it cheaper than a new DCX? btw, I bought one in the end, here's the result: |
app
Old Croc Joined: 26 December 2013 Location: Finland Status: Offline Points: 2435 |
^When will you bring your sound to HKI?
"what!?"
