Building a sound system as a complete noob |
Post Reply | Page 123> |
Futendra
Registered User Joined: 28 April 2016 Location: Belgium Status: Offline Points: 276 |
Posted: 28 April 2016 at 10:12am |
Hi!
Me and a friend would like to build our own sound system, but we have almost no knowledge about speakers. The idea is to build: 2x 186 Horn 2x MT 102 I know that I need a 3-way crossover first, so we are looking for one right now (currently talking to someone for a DAP Audio ACX-34), but the main problem is that we do not know if we can put any cheaper drivers in these cabinets. Are there any lower-budget drivers that would work out in these? The things that I found that could be within our budget range are: 186 Horn: Eminence Sigma Pro 18A-2 MT 102: Eminence Delta 10A Eminence APT150V2 Are these "compatible" with the cabinets? If not, what should I look for and what should I consider? What would I need next? Edited by Futendra - 28 April 2016 at 10:20am |
all bass
Not compatible!
For 102 you will need a 10 inch with "horn" specs. Compare the recommended drivers vs the delta... And a big and potent compression driver to be able to cross low enough to the 10" drivers to avoid beaming. |
Futendra
Thanks! Any recommendations for a budget? I don't really know how do compare the drivers, I don't quite understand what differences in driver are acceptable. Is the Eminence Sigma Pro 18A-2 good for the 186 horn? Sorry for the stupid questions. |
RUS
Maybe tell us what your current budget is ? I'd buy used cabs me there is so much saving to be done !!
Futendra
There is no current budget, but I guess around €500-1000 to begin with? |
RUS
One thing you need to tell us is what is the purpose of this system eg what do you want to do with it 😜
cravings
500 - 1000 is the budget for ... everything? or just for some drivers?
Futendra
It would be the budget for everything excluding wood.
It would be for techno, breakcore, acid, ... parties. Edited by Futendra - 29 April 2016 at 3:39pm |
Futendra
I found 4 JBL 2242HPL's second hand. Are they "compatible" with the 186 horns?
all bass
Why not build some reflex boxes? Start with 2, and try to buy two decent 12+1" tops. Do a few gigs, make some money, build 2 more subs.
Mikkel
Young Croc Joined: 17 May 2013 Location: Huddersfield Status: Offline Points: 549 |
I would agree with allbass, reflex much easier to build and build upon but amp cost practically double (also less channels) so its up to you where you wanna save your money.
What drivera do you have available where you are? |
Mikkel
Sorry no, afaik very much reflex drivers |
