BULLDOZER |
Post Reply | Page 12> |
suiluj
Registered User Joined: 28 November 2007 Location: Phil/Singapore Status: Offline Points: 202 |
Posted: 19 August 2016 at 7:12am |
BULLDOZER VERSION OF PD, 82KGS
Nominal Diameter - 18inch Sensitivity(1w/1M)- 98.5 Frequency Range - 36Hz - 1000Hz Voice Coil - 6 inches Fs - 36Hz Re - 4.5ohms QMS- 9.41 Qes - 0.23 Qts - 0.22 VAS - 109 MMs- 353 BL- 40 xmax - 12mm Need a Nuclear Power Amp...
Edited by suiluj - 07 September 2016 at 5:15am |
BooM BASSTIK EleCtronics and Communications Engineer
Live in harmony with one another. Do not be proud, but be willing to associate with people of low position. Do not be conceited. |
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
what the hell is this ?
Peter Jan
Young Croc Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1019 |
A BIG speaker obviously...
It's not the first time something like that pops up. Can't tell from the pictures whether thees are real and working specimens, but if so, can't imagine them to be efficient compared to size, weight, cost and power needed. Still fun to see though |
Hemisphere
I think that's the place that builds in-ear monitors for Cthulhu.
Hemisphere
Waste of metal if you ask me though. You could make 6 good quality drivers with that much material and produce a better result for most applications, you'd even get 3x21 or 2x24 inch monsters if that's what you really want. Precision Devices do 24s but they mostly get used for show and for theatre/theme park earthquake style effects where the subtle timbral difference of having an enormous drive unit vs several lesser units is worth the excess, but for general purpose applications the tradeoffs just aren't worth it. If you're able to justify a whole section of your rig for the sub-40Hz band (with 200 kilo cabinets..) that could be good, playing above that and you'll be sacrificing sound quality for rumble quality.
suiluj
X-line Bulldozer series, this is the mid version, also triple stack magnets..
Used in Battle of Sounds, Ilo-ilo,Philippines mini soundsytem below.... Edited by suiluj - 19 August 2016 at 9:55am |
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4576 |
Looks like a cheap in car sub. Will take 6kw and spit out meh.
toastyghost
Nice and proud old Behringer logo on the bottom left of that last photo's banner!
Sundip S
New Member Joined: 19 August 2016 Location: birmingham Status: Offline Points: 1 |
my back hurts just looking at those!
odc04r
You have to respect the Philippines for the lengths they go to with systems, even if it seems crazy.
suiluj
Excavator 18inch
Fs = 32Hz Re = 5.4Ω Qms = 12.4 Qes= 0.32 Qts= 0.31 Vas= 139 Mms = 365 Sd= 1225.42 Cms= 65µm/N BL= 36 T/m Magnet Diameter = 300mm Total Magnet Thickness = 60mm Voice Coil = 6 inches |
suiluj
